bonjon1979
bonjon1979
30
Can someone link me to the permitted engine development chart for next year. Thanks.
Juzh
161
You mean This?
Or this:
f1 2014 technical regs
Last page is what you're looking for.
Have a dumb question: how the hell can you increase RPM from 10500 to 15000 if fuel and air flow are constant and the engine has no variable valve timing ? you use the KERS?
langwadt
langwadt
Blackout wrote:Have a dumb question: how the hell can you increase RPM from 10500 to 15000 if fuel and air flow are constant and the engine has no variable valve timing ? you use the KERS?
as long as the engine makes more power than is needed to push the car through the air the car with be accelerating, thus the rpm increasing, there is no trickery involved
mrluke
mrluke
Less fuel per revolution, same fuel per hr :)
I dont fully understand
Blanchimont
Blanchimont
214
Don't forget that there are two electric mgu(motor generator unit)s!
At first i would optimise the valve timing and lift for a rpm of ~11500, this seems to be the most common rpm used. We know that the turbo is capable of delivering enough air into the engine and at the same time can provide power for the mguh to power the mguk to power the wheels. If the software detects that the turbo delivers less air than needed for best combustion energy from the battery is used to spool the turbo up via the mguh(=motor mode). If on the other side the software realises that the turbo provides too much air for an ideal combustion, the mguh switches to generator mode. As a generator the mguh slows the turbo down or makes it stay at the same rpm and this limits the amount of air that can enter the engine and the air to fuel ratio is ok.
650
I don't know why you would want to do this .....
and why the airflow would need to be constant, but ......
you have full control of boost and the mean exhaust pressure aka backpressure via the mutually independent mgu-h rpm and load
so you can charge with less air/rev and less fuel/rev ie same AFR less mep
or achieve this same AFR but cut the charge with exhaust
or let the AFR increase
or run not eg at 10000-11500 rpm mostly, but at eg 13000-14700 mostly
or some combination from the above
474
As Langwadt says, so long as the engine has more power than is required to drive the car at a set speed it will accelerate.
569
What you end up with approximates a "constant power" engine. This is common in electronic injected diesels where the fuel rate is mapped so that power is constant over a significant rpm range - say 1500 to 2100. The fuel flow to achieve this will be approximately constant (usually increasing somewhat to account for decreasing TE, as friction and other losses rise with rpm).
Of course diesels can operate with a wider range of AFR than SI engines, so the F1 engine will typically need reducing boost above 10,500 to obtain a near constant airflow - if constant AFR is required.
olefud
olefud
79
I don’t see why you’d do it in a perfect world with a choice of gear ratios. But if you’re limited to a ratio optimum for the average course but too short for a specific course, overreving at a bit reduced power is better than not doing so.
Wayne DR
Wayne DR
ian_s wrote:Just put a recovery turbine and GU-H in the exhaust (no need for a motor part, no forced induction)
all the time you are at full throttle its recovering exhaust energy, maybe at a cost of crankshaft HP due to back pressure but there should be a good amount of 'free' hp available
No so sure about the no need for the motor part, an MGU-H on a V8 could be used to bring back blown diffusers/floors... :D
Cold Fussion
Cold Fussion
93
For a particular gear ratio, the power curve vs vehicle speed looks like above. Power to overcome the aerodynamic drag is cubic with vehicle speed. So long as the vehicle is transmitting more power to the road than the power required to overcome the aero drag, the vehicle will keep accelerating.
If the fuel flow into the engine is constant, and for simplicity, the airflow is constant for constant fuel flow (it may not be in the case for these engine), then it means the average power per engine cycle is lower, but because there are more cycle the output power is the same.
Thanks to everyone for the answers :)
Richard
Richard
I came across this MGU-H image from Marelli. So the turbo is on the left, MGU-H is the tube with the Marelli sticker, the compressor is on the right?
I also found this image of the Renault turbo (or it might be a decoy):
Image (http://forum.b92.net/topic/72645-novi-v6-f1-motori/)
A google search for the first image lead me to a sketch for a split turbo/compressor with a shaft down the middle of the V from Jan 2013 :o by Matt Somers. http://somersf1.blogspot.co.uk/2013/01/ ... h-ers.html
That's a coup on par with manchild's prediction of the 2008 Ferrari nose vent http://www.f1technical.net/forum/viewtopic.php?t=4589
