Driver styles/preferences
SectorOne
Re: Driver styles/preferences
raymondu999 wrote:No - actually, the tunnels only worked at high enough speeds - the end result was a car that understeered unpredictably in the fast corners - and it was this understeer that Webber coped with better. It's not oversteer that Vettel has trouble with - it's understeer.
Oh it was definitely oversteer, i just watched the sessions.
raymondu999
The question is - was that oversteer a characteristic of the car, or was it oversteer that was induced, so as to cut down the understeer?
I notice you also chose to completely ignore the Mark Webber quote I provided?
失败者找理由,成功者找方法
SectorOne
Corner entry oversteer, pretty rapidly as well, not where you force the car in and it just lets go completely.
Yes i´ve read Webber´s quotes, read all other quotes as well, i´m fully aware of them going against what i saw.
For me in terms of 2012, when the car is chaos, whether that is bad setup or tricky car overall, or tricky rear end.
Webber has to my eyes always been the most comfortable guy turning chaos into order.
Like Alonso and Hamilton who can drag stuff out of the car even though it´s a complete disaster.
To me i have always hade the impression that unless the car is perfectly tuned in, Vettel is the one experiencing some more problems.
But there´s not fault in that, Raikkonen is the same, it needs to be a certain way.
raymondu999
Let's agree to disagree
失败者找理由,成功者找方法
Kansas
Kansas
-3
SectorOne wrote:Corner entry oversteer, pretty rapidly as well, not where you force the car in and it just lets go completely.
i have never read that much crap at once.
SectorOne
Clearly you can produce crap of your own looking at your rating. So i guess a bullshitter recognizes bullshit.
No? Then i guess that settles it then.
You could have constructively pointed out the proposed fallacies but i guess that´s a bit more hard these days.
Monaco is a great example, Vettel complaining the car was jumping around like a Rabbit while Webber took pole.
Can you imagine how wrong the setup must have been for low fuel running in order for him to completely abandon Q3 and focus on the race instead?
raymondu999
SectorOne wrote:Monaco is a great example, Vettel complaining the car was jumping around like a Rabbit while Webber took pole.
To be fair - that was Vettel getting a wrong setup, rather than Webber coping with a wrong setup better. Webber didn't make the same setup mistake (which was a change only Vettel did to his car after Q2) - which means it was probably a diff or front wing change
失败者找理由,成功者找方法
Stradivarius
Stradivarius
SectorOne wrote:Clearly you can produce crap of your own looking at your rating. So i guess a bullshitter recognizes bullshit.
How does this indicate that Webber is better than Vettel at dealing with a sub-perfectly tuned car? Couldn't it simply be a result of the car incidentally behaving more to Webber's liking at some tracks? I think we see this all the time in teams with two evenly matched drivers. Some times one driver is quicker and some times the other driver is quicker without it being a result of car problems. I would usually call it a result of more or less random variations.
When speaking of Vettel, Webber and Red Bull, assuming the drivers are getting equal treatment, everything points towards the opposite, as Vettel obviously gets the setup right and performs better more often than Webber. However, this is probably not a realistic assumption, so let's assume that the drivers don't receive equal treatment:
I guess it's reasonable to think that Vettel has a higher star within the team and that the team tries to design and develop the car so that it behaves to Vettel's liking. To the extent that Webber has different preferences to Vettel, I think it is fair to assume that Vettel will normally reach a higher level of optimization than Webber when everything goes as planned becaused the car and driver match each other better. This explains why Vettel is usually quicker than Webber (other than the very plausible explaination that he is in fact a better driver). But this also means that Vettel has more to loose if they experience some sort of problem with the car setup at a certain track. Vettel's performance will drop more than Webber's because Vettel initially performs better. So if we include the random variations that some times give one driver an advantage and some times give the other driver an advantage, it is more likely that Webber will beat Vettel if they have set up challenges. Some times Vettel will beat Webber despite the set up challenges, but then nobody will notice because the results are normal. But some other times Webber will beat Vettel and people will notice two things: Red Bull struggled to get the setup right, and Webber beat Vettel. This may lead to people concluding that Webber is less vulnerable to set up problems, while in reality this has nothing to do with the drivers, other than the fact that Webber's normal standard is lower.
I am not claiming the above to be the case, but I don't think it is less plausible than saying Webber is better than Vettel at driving a car which is not perfectly tuned. It occurs to me that Vettel is better and more consistent than Webber. Your impression could just as well be a result of Vettel having a perfectly tuned car more often than Webber.
Another point worth mentioning is that set up problems might be an expression used only when Vettel experiences them. If Vettel doesn't experience set up problems, but Webber does, it might not be understood in public that they had set up problems.
SectorOne
All im saying is that when the car is having issues, like early 2012, from what i see on track, Vettel has been the one having more trouble with the car. Webber has been the one that simply deals with it.
I´m sure everyone disagrees and i bet some people think i´m solely doing this to hate on Vettel which could not be further from the truth.
We all know you are a Vettel fan, who used to be neutral but nowadays is openly tilted towards Vettel,
(which is nothing wrong with but it sort of skews discussions quite a lot when it´s such a clear bias, bit like mnmracer)
And i´m not alone in noticing that if you were to read some of the PM´s i´ve recieved.
A response will probably be soemthing along the lines of "oh but you are a Hamilton fan" which is correct.
But you´ll never hear me smear over mistakes from Hamilton or say he´s the best driver in the world because that would be stupid, illogical and irrational.
I just look with my own two eyes and make an opinion about the situation, regardless of who is involved.
An example of fanboyism, from you.
2013-spec Vettel IS infallible on formation laps, yes.
This is (and excuse the language) crazy-talk.
It´s impossible to have constructive discussions with a guy that makes these sort of statements.
So what will happen is one of us will propose the words "let´s agree to disagree" to which one of us will concur and nothing will come out of it.
mnmracer
mnmracer
-26
SectorOne wrote:It´s impossible to have constructive discussions with a guy that makes these sort of statements.
Less possible so then a guy claiming a certain driver is on a completely level of the others, "no competition"?
It's getting a little tiring to have you hide behind "I'm totally unbiased, thus whatever I say is the truth" with some of the statements you are throwing around. And it'd be one thing if those statements are backed up by facts or by the majority of pundits, but frequently enough they aren't.
If you feel too good to discuss with us measly 'biased' persons, you don't have to.
JimClarkFan
JimClarkFan
27
I don't know if either Vettel or Webber is better at driving around problems but amongst Sectors points there is something of interest in there somewhere.
At the beginning of the 2012 season, when the blown diffusers were banned, it was Webber who was qualifying best out of the red bull drivers.
http://www.f1technical.net/forum/viewto ... =1&t=13372
I remember when red bull got an upgrade around the beginning of the European season which worked the diffuser better, Vettel once again came out on top and dominated Webber for the rest of the year. Up till that point, Webber had beat him in all but one quali I believe.
I think Vettel is a maestro in that Red Bull, maybe even untouchable when he has all parts of the Red Bull car working how he likes, however I get the feeling that he operates well only within the confines of a car set up suited to his particular style of driving.
When I think of Vettel I think of a Prost more than Senna, or a Button more than Hamilton; the former being able to only extract everything when the car is within their operating window of their preferred driving style.
Senna, Hamilton and Alonso by contrast just drive the wheels of anything, irrespective of setup.... however I think there is a disadvantage in that too... I think those guys who can get just in and go perhaps have a bit of trouble setting up a car to exploit it 100%. Certainly you could argue that for Senna and Hamilton... Alonso less so.
mnmracer
mnmracer
-26
JimClarkFan wrote:At the beginning of the 2012 season, when the blown diffusers were banned, it was Webber who was qualifying best out of the red bull drivers.
He was only qualifying better though.
I'll make my point later, because first I would like to know what you think of it.
2009: Vettel outperforms Webber in qualifying AND races.
2010: Vettel outperforms Webber in qualifying AND races.
2011: Vettel outperforms Webber in qualifying AND races.
There is no significant discrepancy between qualifying performance and race performance.
Early 2012: Webber outperforms Vettel, but ONLY in qualifying.
If Vettel struggled as much and couldn't adapt as much, one would assume that would also translate to race performance.
What is your view on this difference?
mnmracer
mnmracer
-26
JimClarkFan wrote:I get the feeling that he operates well only within the confines of a car set up suited to his particular style of driving.
I think this is one of the reasons there is such a difference in opinion between the two sides here.
It appears you are very much locked in the idea of Vettel's "particular style of driving", but some of us see things that simply don't match with that idea.
So please, let's try and understand each other.
If Vettel has this particular style of driving, which relies (heavily) on rear-grip, how do you explain Vettel's performances in Torro Rosso, a car where with the exact opposite characteristics. How do you explain Vettel being one the best drivers in the wet, a situation generally lacking rear-grip. And how do you explain Monza 2008? And I don't mean "the Torro Rosso was good that weekend", but if you take a step back and look at it, that weekend was everything which is claimed Vettel can't handle well: he drove a car with little rear-grip, in the rain, on a track with ultra low-dowforce, AND with a dry weather set-up in the pooring rain. If it was the Torro Rosso, Bourdais, who had a set-up suited to the conditions, would not have ended up where he did. Everything was against the Vettel who is pictured here, the Vettel who needs a planted rear.
And that is perhaps the biggest issue. That Vettel likes his rear planted, sure, we all seem to agree on that. But I, and others, can not align the idea of Vettel "operates well only within the confines of a car set up suited to his particular style of driving", with what we have seen. We can not explain Torro Rosso, we can not explain his rain driving and we can not explain Monza 2008, with the idea that Vettel has trouble performing unless the rear is planted.
I hope maybe you can give us your view on those three points. How do you align a statement as you've made, with the performances we've seen that seemingly contradict that statement?
JimClarkFan
JimClarkFan
27
I said qualifying at the beginning of 2012, with no mention of races. If you don't understand the point I am making I suggest you reread the above post. If you want to make another point about racing then by all means do, but understand, that was not the point I made.
JimClarkFan
JimClarkFan
27
mnmracer wrote: I think this is one of the reasons there is such a difference in opinion between the two sides here.
A few things need cleared up before I get to the point.
I am not following you logic in several places: You say the Torro Rosso was the exact opposite of Red Bull, which I presume to mean it had a good front grip and poor rear grip, but you have nothing to back this up - how do you know this? You are also assuming that Vettel didn't have his car set up to exploit rear grip, in the wet and dry - again how do you know this? You are also talking about rear grip as being less in those conditions, but I want to know, less relative to what? It should be clear I am talking about relative rear grip to the front, not absolute rear grip in different cars or conditions. You are also trying to make claim that we should take equal consideration of a one off performance in Monzo 2008 in a car not well understood versus several races at the start of 2012 with a car which we understand very well - why?
Vettel has spent 4 years excelling in a Red Bull, a car highly studied and a car whose characteristics are well understood. It makes more sense to judge Vettels driving style on that basis because we can track changes in the Red Bulls characteristics fairly easily over those years therefore giving us a better platform from which to judge Vettels performance by. I spend all day doing relative quantification as part of my job, and if you don't have a stable reference you can't make any accurate measurement of the target. The reference in this case is red bull, and what we are measuring is Vettels performance. The Torro Rosso win at Monza was a one off, whether you wish to admit it or not. Sure Vettel drove well, but there were a lot of other factors that helped him along the way that weekend. You are asking us to judge Vettel from a one off performance in Monza, in a car whose characteristics was never as closely followed as the RBs, and therefore not nearly as well known as the characteristics of the Red Bulls. How can we accurately measure Vettels performance when we have a shoddy reference? Additionally Vettel has spent a much shorter span of his career in the Torro Rosso compared to RB, since then Vettel has claimed 3 world titles and his driver style has come under much more scrutiny. Given these facts, does it make sense to use his time at Torro Rosso as a suitable reference for Vettels driving style or could more credence be given to his stint in RB?
Lets get some other stuff cleared up too. You are using rear grip in manner that incorrectly implies absolute rear grip. When people refer to rear grip, often they are talking specifically about a car which has the characteristics of the front sliding first. It is a relative term which you are using in an absolute fashion. You can have a car with poor overall grip yet it still might have a grippy rear relative to the front. The rear is simply said to be grippy because you never bring it to a point where it could slide, because the front slides first thereby preventing any sliding of the rear. By way of an example, you can have a car with much more absolute rear grip, say a Red Bull, than a car with much less absolute rear grip, say a Torro Rosso, but yet both cars have characteristics of a grippy rear. This is because on both cars the fronts reach their limit of grip before the rears, relatively speaking both cars have better rear grip despite one car having much more absolute rear grip. I find it very confusing when you throw around rear grip in the manner you are doing (wet weather, Torro Rosso vs RB) - it doesn't make sense.
To the point at hand.
It is not a contradiction to say that Vettel likes rear grip and to use oversteer. Vettel exploits consistent rear grip by inducing the car to oversteer on entry. If a car has poor inconsistent rear grip Vettel doesn't appear to be able to manipulate the rear to his liking - as seen in early 2012. Since you have no provided no evidence to suggest that this is not the case, I see no reason to change my opinion.
