FW17
171
Pierce89 wrote:
Pierce89 wrote:
WilliamsF1 wrote:The Merc engine has a log style exhaust, which in turn is a variable length exhaust
Does Merc have a variable length tuned intake system to compensate/compliment the exhaust system
a couple of systems come to mind
http://www.njstangers.org/members/norm- ... 3-vris.jpg
http://i181.photobucket.com/albums/x79/ ... MG1132.jpg
The log is a variable length exhaust? Care to elaborate?
Bump. Just wanted an answer. Did you simply mean it has unequal length primaries?
Yeah
A log is a unequal length by itself
570
xpensive wrote:Which is xactly my point, an ICE-efficiency of 40% is pure fantasy, 35 would be impressive enough.
Not at all. Anyone can walk into a Toyota dealer and buy a Prius with an NA SI ICE running at 38.5% TE. Many labs have NA SI engines operating above 40%. Turbo-compounding makes that number even higher.
lio007
324
lio007 wrote:According to AMuS: http://www.auto-motor-und-sport.de/form ... 29184.html
- Ferrari and Renault are allowed to use the whole 32 Token (if they can’t finish til 28th Feb they are allowed to use the rest during the season)
So if Renault, Ferrari (and probably Mercedes) are allowed to use the rest of "unused" Token, what do you think about Honda?
Could it be that they are also allowed to make performance changes on their PU during the 2015 season?
(I would say no, because they're not limited to the 32 Token of changes, therefore they haven't any left to use during the season in 2015, like Renault and Ferrari)
Any opinion of a "regulation-expert" is appreciated!
Mesteño
Im no expert, but found this:
The homologation regulations are pretty clear . They are controlled from year to year. Does that mean for Honda, that you must not change so much next year as Mercedes , Renault and Ferrari after their first season?
Yasuhisa Arai : Honda 2016 must freeze as much from the engine , like the others . The token system is exactly the same and also the schedule. We can not take the 32 tokens as the manufacturers this year , but only 28th
http://www.motorsport-magazin.com/forme ... iel-power/
For me it means Honda PU will freeze on February 28th. Then Honda will be able to develope 28 tokens for 2016, but not the rest of the teams -seems odd to me-.
Someone correct me if wrong.
481
He is saying that they get none for this year and only 28 for next year - which is the same as the others. They follow the token schedule the same as the others from next year.
Mesteño
Thanks, I made a misunderstanding and I think that didn't answer his question.
My mistake.
lio007
324
Thank you guys, wuzak & Mesteno.
So all in all, if the regulations are changed, Renault, Ferrari (and Mercedes) do have the possibility to make performance changes during 2015 season, Honda not.
650
the Prius presumably has its best BTE of 38.5% at some partial power (ie close to max torque)
not at or very near maximum power as in F1
presumably the Prius BTE at max power is substantially less than 38.5%
J.A.W.
J.A.W.
109
Other than both seeking high fuel efficiency..
..the Prius plainly has a different set of power delivery parameters to F1..
& naturally - 'orders of magnitude' in level of tune/cost/quality/longevity of componentry..
.. so a direct comparison - other than for that thermal % of fuel utilization - is surely invidious,
..meaningful validity-wise?
570
The F1 engines are probably capable of 1500 hp at 16,000 rpm.
Their operating point is nowhere near that.
570
J.A.W. wrote:Other than both seeking high fuel efficiency..
Correct. My post made no reference to F1 - purely a response to Xpensive's claim that 40% (SI) ICE efficiency of 40% is fantasy.
(We all know CI ICE have climbed beyond 50%)
SectorOne
"Indeed the power unit had been said to be the most efficent gasoline power train of all time"
- http://www.racecar-engineering.com/news ... a-1-guide/
That´s impressive if it´s true.
It still is fantasy. haha.
Even getting steam turbines from 49% to 50% efficiency was seen a significant achievement in the last decade. A percentage point of efficiency is no mean feat so 38% is not in the same league as 40%. two different worlds.
650
Tommy Cookers wrote:the NACA report 822 tells us what we need to know (as shown particularly in Fig 7 and Table III)
it's based on the R-2800 with 40deg valve overlap
because it has some sea level data it is much more useful than NACA 1602
the best bsfc at sea level is with a delta P of -20" Hg
and the best bsfc is consistent with best combined power
at 10000' power recovered is 263 hp and net ('crankshaft') power is 1043 hp with 85% turbine and 94% transmission efficiencies
this recovery figure is after the deduction of supercharging power
this is at -8" Hg delta P
a bit of mental extrapolation shows clearly that there would be more recovery at sea level
because of the best bsfc - delta P even with more overlap would be close to the above -20" Hg, say -15" Hg or -0.5 bar
and this gives more turbine power, as exhaust pressure is greater relative to ambient (than eg at 10,000')
I would say that efficient recovery of 30% of crankshaft power is available
(this is the crankshaft power at -0.5 bar)
because this 'backpressure running' gives the greatest efficiency
see link in post below
650
Tommy Cookers wrote: http://naca.central.cranfield.ac.uk/rep ... rt-822.pdf
the combined power is always best around best bsfc
best bsfc is with -20" Hg on the engine used (probably -15" Hg on an engine with more liberal valve timing)
ie the loss at the crank is the same or less than the gain via the MGUH as the delta P becomes more negative
so 120 kW recovered power might cost 100 kW crankshaft power without any fuel rate limit
but the bsfc as reported is 14% better at 10000' than the same engine with turbo
extrapolation suggests 10% better at sea level
so under a fuel rate limit there's 10% more combined power with this level of compounding
but the F1 engine 'boost' will be much higher, so the best bsfc delta P might be more, maybe close to -1 bar ?
so the bsfc gain over an equivalent turbo engine should be maybe 15%
(because recovered power is largely due to the pressure difference between exhaust pressure and ambient)
giving 15% more combined power with this 'best bsfc' level of recovery
of course a suitably big MGUH and related electrical system is needed
a lower level of recovery such as Wright actually used would according to this report give only maybe 7% bsfc gain
(at lower recovery levels the bsfc gain comes from recovery that costs very little crankshaft power)
and so only 7% more combined power under a fuel rate limit
but would use a much smaller capacity MGUH and related electrical system
with a turbine-electric recovery system as in new F1 .......
in a low recovery level system the electrical power can reasonably described as free
as the efficiency improves in proportion to the electrical power
at maximal recovery level as in NACA 822 only about half the electrical power can be regarded as free
because the efficiency gain is 'only' about half the recovery level
so we should resist the inevitable media and PR attempts to tell us that eg a 120 kW MGUH recovers that much 'free'
NACA 822 is based on running at pressure (loosely, 'boost') of 40" Hg Abs (about 1.35 bar Abs)
the supercharger power is rather low, around 3 % of output power
just bumped these 2 posts for the link - might be useful for those who haven't read the whole thread (from around p 355)
maybe gg will take NACAs word that running at true backpressure is good if the exhaust valve closure is suitable ?
raised exhaust pressure helps reduces blowdown losses (my story - and it features in eg Caterpillar's compound piston patent)
and improves efficiency of the turbine expansion phase (gg's story iirc)
