What and have NASCAR style competition cautions? no thanks!Wayne DR wrote: Should the FIA be trying to stop drivers putting themselves in these situations?
No. The FIA should make sure that it is safe for a driver to leave the track and crash into the wall, which it failed to do here.Wayne DR wrote:I totally agree! The drivers need to make the call when to change to/from Full Slicks, Inters and Full Wets. This is racing. Button got his 5th place by making the right choices at the right times.mrluke wrote: If the drivers tyres were worn out they should have pitted for new ones. It is not the FIAs job to send out a safety car because some drivers have decided they do not need to pit for new tyres.
The problem is that the car becomes a dangerous weapon if the tyre selection is significantly wrong (i.e. worn inters when full wets are required), and the driver decides to stay out to not lose 20/25 seconds in the pits at the end of a race(i.e. Massa).
I think the numbers you are quoting and m/s², not G's. You need to divide by 9.81m/s² (G) to get G's.emaren wrote: If he 'only' hit at 60km/hr he saw an average deceleration of 64G for about a 1/4 of a second.
at 100kmh - 106G
at 130kmh - 138G
if it was up around the 200kmh/hr rate- 213G
Its never going to be safe, hitting a wall in a car. Its not possible to be safe. Safer maybe. But not safe. And as for the kimi accident, the safety car was deployed and rightfully so as there were multiple cars involved and huge amounts of debry across the track! Where as Sutils crash was way off the track and only the 1 car. Its crazy to try and compare the 2 accidents.Regle wrote:
I agree with what has been said a few pages earlier, there's no doubt in my mind the SC should have come out.
Räikkönen hits the wall in an extremely weird way and at a point where it's very unlikely another crash will occur -> no objects, let alone entire heavy vehicles on the track -> still: SC (rightfully so, in my opinion).
A car slides off the track due to aquaplaining (if it happens once, it can – it will happen again), heavy rain, degrading tyres, a tractor a few meters in the trajectory of the racing line -> no SC?
A slightly damaged barrier in dry conditions poses a threat to a driver while several tons of unprotected steel and marshals on track in the rain don't? This is insane.
Aquaplaning is not only a function of the amount of water on the track, but speed as well and most definately the state of tyres. How do you judge if a car hasn't simply aquaplaned off the track because of either too much speed or inadequate tyres or both?Regle wrote:A car slides off the track due to aquaplaining (if it happens once, it can – it will happen again), heavy rain, degrading tyres, a tractor a few meters in the trajectory of the racing line -> no SC?
Ehm, no. Aquaplaning has to do with loss of traction when water isn't dispersed sufficiently enough and causes the tire to lift and lose contact to the road surface. How much water can be dispersed depends on the state/type of tire (more specifically, its grooves), the amount of water on the surface, the speed of the vehicle and weight (+ downforce) of the vehicle among others. Worn tires offer less depth in the grooves which means less water that can be dissipated.mrluke wrote:Aquaplaning is primarily about ride height.
That´s a great angle!Juzh wrote:Funny how fan videos can give more thrills than what fom can manage.
I think it's both, because a typical rain setup would have a heigher ride height, but if your tires are worned out, then the height won't even matter tbh.Phil wrote:Ehm, no. Aquaplaning has to do with loss of traction when water isn't dispersed sufficiently enough and causes the tire to lift and lose contact to the road surface. How much water can be dispersed depends on the state/type of tire (more specifically, its grooves), the amount of water on the surface, the speed of the vehicle and weight (+ downforce) of the vehicle among others. Worn tires offer less depth in the grooves which means less water that can be dissipated.mrluke wrote:Aquaplaning is primarily about ride height.
A typicall rain setup has indeed a higher ride height but i think it is more due to the fact that you can run a softer suspension then.WaikeCU wrote:I think it's both, because a typical rain setup would have a heigher ride height, but if your tires are worned out, then the height won't even matter tbh.Phil wrote:Ehm, no. Aquaplaning has to do with loss of traction when water isn't dispersed sufficiently enough and causes the tire to lift and lose contact to the road surface. How much water can be dispersed depends on the state/type of tire (more specifically, its grooves), the amount of water on the surface, the speed of the vehicle and weight (+ downforce) of the vehicle among others. Worn tires offer less depth in the grooves which means less water that can be dissipated.mrluke wrote:Aquaplaning is primarily about ride height.
