Ferrari F2012
Richard
Richard
Re: Ferrari F2012
Henning wrote:Is it possible to un-stick the threads for last year's cars now? The pre-launch speculation threads now have more activity than these eight or so dead threads.
Done to make browsing easier - no more stickies until each car is launched.
Henning
Henning
Re: Ferrari F2012
Excellent, thanks Richard.
Javert
Re: Ferrari F2012
So, F2012 was poor in qualifying ALSO(or mainly?) because it couldn't heat front tires (Fry's words).
But why was so competitive in lap1?
Got immediately the tires in temperature there
Neno
Neno
-29
Re: Ferrari F2012
Javert wrote:So, F2012 was poor in qualifying ALSO(or mainly?) because it couldn't heat front tires (Fry's words).
for first part of season i agree, but mostly because car had poor downforce and traction. for second part of season Fry was lying, Ferrari was eam who most improved their traction so this caused good competitive times over one lap, they would be even better if everything in wind tunnel worked okay.
timbo
timbo
113
Re: Ferrari F2012
Javert wrote:But why was so competitive in lap1?
Obviously there's a difference in handling with full tank and on fumes. Also, their KERS was very good at the start.
raymondu999
Re: Ferrari F2012
Probably a killer start launch system too
失败者找理由,成功者找方法
FW17
171
Re: Ferrari F2012
Ferrari gearcase
Ferrari shifted to Rear Pull Rod suspension for 2012, this necessitated a new gearbox casing. No doubt the Toro Rosso solution inspired Ferrari approach to their powertrain design. They were perhaps also mindful of the stiffness\weight challenge of split case, so their design is a progression from Toro Rosso’s. With the access benefits of a separate inboard suspension module, but not by employing a split case.
http://scarbsf1.com/blog1/2013/01/22/sa ... uspension/
Gridlock
30
Re: Ferrari F2012
As scarbs has advertising on his blog I don't think it's right to post so much here. Post a summary and a big link. Dragging the images over is even more impolite....
#58
Redragon
19
Re: Ferrari F2012
Not only for the advertising, also for the respect at his work.
If you want to publish or bring attention to his posts, you should just copy and past the first 5 or 10 lines of his article, (one picture at least to illustrate) but after that 5 or 10 lines there should be a highlighted READ MORE... that when you click on it, links directly to his blog.
Nando
Nando
Re: Ferrari F2012
The copyright is there for a reason though.
