60% of real life HxWxL is the same as 60% of the volume since the volume is HxWxLraymondu999 wrote:Is that how it happens? 60% length by 60% width by 60% height? Or is it 60% over volume?
Ummm... no...wesley123 wrote:60% of real life HxWxL is the same as 60% of the volume since the volume is HxWxLraymondu999 wrote:Is that how it happens? 60% length by 60% width by 60% height? Or is it 60% over volume?
raymondu999 wrote:Ummm... no...wesley123 wrote:60% of real life HxWxL is the same as 60% of the volume since the volume is HxWxLraymondu999 wrote:Is that how it happens? 60% length by 60% width by 60% height? Or is it 60% over volume?
60%H x 60%W x 60%L = 21.6%HWL
If you had a box that was exactly 1 cubic meter, (1m x 1m x 1m) then 60% of the volume would mean .6 cubic meters. If you had it 60% length each way, that would mean 60cmx60cmx60cm, or .216 cubic meters
remix wrote:Ok thxChuckjr wrote:Look for where it says "Acer" on the side pod rear. That's the ramp.remix wrote:Sorry, but what is a acer ramp? The sidepod?
Is there any limit to the wind tunnel testing? Or is that allowed 24/7/365
Its allowed but the problem is the costs ( fia has introduced costs reduction) there are rumours that redbull as only team do not follow the rules and explodes his costs but is not easy to prove that.
Not to mention time: with only 1 windtunnel allowed, there are only 24 hours a day (which even might be 8 hours a day) you can really use to test parts. New parts are also much more difficult to make: either you have to redesign large parts of the car, or you have to introduce small parts which make complex changes in the way aero is working on the car. Both need alot of development and aren't seeing that quickly windtunnel light.Huntresa wrote: There is a limit to how much Wind Tunnel you can do, not just cap on costs.
The car in the video and picture looks proper size doesn't look Nealy half the size of a normal carremix wrote:Hi chassis
Can u confirm ur post? Have you a source?
@adam: yes the original car is 100% and in wintunnel is the car 40% smaller = 60% from the original
Example 50% in windtunnel= if the original car is 3meter length in windtunnel the car is only 1.5meters
Thank you
Greets
If you have looked at the video you know its not 100%, 3minutes and 25sec you can see how big the persons are compared to the car.adam2003 wrote:The car in the video and picture looks proper size doesn't look Nealy half the size of a normal carremix wrote:Hi chassis
Thank you
Greets
22.4(c)(iii) Four one day aerodynamic tests carried out on FIA approved straight line or constant radius sites between 1 January of the current year and the start of the last Event of the Championship. Any of these days may be substituted for four
hours of wind‐on full scale wind tunnel testing to be carried out in a single twenty four hour period.
22.9 With the exception of the full scale testing permitted in 22.4(c)(iii) above, no wind tunnel testing may be carried out using a scale model which is greater than 60% of full size.
22.10 No wind tunnel testing may be carried out at a speed exceeding 50 metres/second.
Seeing how they hold the model, I am no longer surprised that not much attention is paid to helmet aerodynamics.Huntresa wrote:Mod Edit - this post and next couple of pages moved from F2012 thread.
_________________________________________________________________________________________________________
amouzouris wrote:Great shots of wind tunnel testing:
The car is connected to the vertical rod holding it in place not on top of the tv camera pod like other wind tunnels but inside the cockpit
Is that Ferraris own Wind tunnel tho ? I mean are the shots zoomed or is it 100% ?
