Harvey wrote:bhallg2k wrote:This is such a weird topic.
The rules have made the cars virtually identical. I mean, the parity in F1 these days is unheard of. But, because of that, the races would be processional without the performance differentiation provided by funky tires. So, on one hand, the characteristics of the tires are absolutely vital to what most seem to call a "great season."
Yet, others - including me - see the tires as detrimental to good, hard racing because of the way they must be nursed around the track for any hope of longevity. The solution is a more robust tire, which, due to F1's parity, would likely cause processional races. See: above.
So, what do you do?
I agree with the aero/tyres bit.
But the bold bit. When they were having to do just that with the 80s turbos, they were lauded as heroes of the highest order. Why is nursing an engine on the precipice of death any different to nursing a set of tyres on a very similar precipice?
There was no aero/tires bit. I do not recognize a correlation between aero-dependance and processional racing. Those things have absolutely nothing to do with one another.
I do, however, recognize the
coincidence of an increase of processional racing in a series that also became more aerodynamic at the same time. But, they aren't related at all.
Processional racing is the result of one of two things: a narrow formula that produces cars with very similar performance levels or a wide-open formula that produces cars with very different performance levels. The only difference is the gaps within the procession.
In the case of a narrow formula, the processions are the result of cars that tend to want to occupy the same spot on the track at the same time, because their performance levels are roughly the same. Physics tells us that's simply not possible. So, the cars then follow each other closely in a procession.
In the case of a wide-open formula, the processions are inevitably the result of one group of cars blitzing around the circuit while other cars struggle to keep up. The races then are processions of vastly different engineering projects.
However, in both cases, aerodynamics is neither friend nor foe. It's just a factor that, at most, affects the gaps between cars.
To answer your question - and stop this needless rant - nursing a monstrous turbo to the end of a race was a necessity because having a car equipped with a monstrous turbo was required to be competitive against other teams that also had monstrous turbos. Competition made that a necessity.
People, not competition, decided that funky tires are a necessity. They did so when they decided that the formula should rely upon varying levels of performance of funky tires to supply the "just right" porridge of performance differentiation that different formulas had thus far apparently failed to achieve. I view this as a crutch-type solution.
I, for one, would rather see an open formula that relies upon talent and ingenuity to prevent processional racing. But, I understand that processions might happen regardless of talent and ingenuity. I just don't particularly care.
