Ferrari F138
ell66
ell66
Re: Ferrari F138
Expected a bigger difference to last years car, unless it changes radically I dont see it being as quick as the 28.
sknguy
sknguy
Re: Ferrari F138
Those rear wing endplates have quite the array of louvers and slots. Be interesting to see how those'll change.
Rhodium
25
Re: Ferrari F138
there is no sense between this photo
and this one, isn't it?
if the first is to show that the nose is higher, so why is not he on the other picture?
in reality, the cockpit appears to lower the nose and slightly above, but this is due to the cache.
reality, I think they are essentially the same.
it would be even more true if the comparative picture (taken from the front) can compare the latest version of the F2012 (GP of brazil for example) with the F138.
I would be willing to bet that would be almost the same.
same for those who think that the pontoons (?)( it's the right word ?) are lower ... they are compared to the version of the F2012 presentation. but not in the version "end of season" of the F2012.
FW17
171
Re: Ferrari F138
Is it me or does the car look candy apple - pink?
amouzouris
105
Re: Ferrari F138
a lot of changes on the car! quite a revealing car launch, fairly new rear and front wings. the gearbox has been stretched out... completely new rear suspension covering the drive shaft ( because of the magnus effect the drive shaft creates some downforce but it is covered by the lower rear wishbone thus not creating any downforce, because of the exhaust blowing on it creates an issue as the exhaust is constantly blowing on it) very very interesting rear end. with strakes on top of the diffuser like the ones redbull used last year, and very interesting rear brake ducts.
Coming to the nose...the yellow highlighted region is the area the nosecone is not allowed to be in... gives you an idea of where the modesty panel is.
Edit: In addition, the black bodywork around the exhaust is most certainly changing, both ferrari end macca are not showing us what they have yet
radosav
radosav
Re: Ferrari F138
WilliamsF1 wrote:Is it me or does the car look candy apple - pink?
is it me or that car looks to have very tight rear end (if you remove that shark fin)?
Re: Ferrari F138
Again, those are rough comparisons. We are comparing the shapes not the dimentions. Angles and sizes are not meant to be identical. but they are close enough
Mind the length of the new nose. It's longer than the other. That's why it does'nt look as high as in the first photo. (add to that the inaccuracy of the angles and dimensions...) : P
DaveKillens
DaveKillens
34
Re: Ferrari F138
Ferrari have also removed the front brake duct.
amouzouris
105
Re: Ferrari F138
DaveKillens wrote:Ferrari have also removed the front brake duct.
not removed...the brake duct inlets are between the tire and the big vertical fin of the brake duct
Redragon
19
Re: Ferrari F138
Rhodium wrote:there is no sense between this photo ... and this one ... isn't it?
From a point of view of a photographer, doesn't make any sense to do those comparations as they are not accurate.
First you don't know the focal lenses, distance and high where the camera was positioned.
If I look at your profile picture comparation. The F2012 was taken more from a central point of view where as the F138 a bit more from a right side, less frontal, with camera looking slightly to the left. If for example the lenses used was a 24mm a really wide angle lenses the distorsion created from the F138 is substantial, so it makes it longer and higher.
Same with the frontal view, the F2012 was taken with the camera in a bit higher position that the F138, just slightly, you can appreciate on perspective. So the F138 looks higher but that could be just an illusion created again by the distortion of a wide angle lens.
Reason: Removed image quoted from earlier post
aral
aral
26
Re: Ferrari F138
ell66 wrote:Expected a bigger difference to last years car, unless it changes radically I dont see it being as quick as the 28.
How did you come up with that assumption? You cannot tell a cars speed or grip, simply on looks alone.
Rhodium
25
Re: Ferrari F138
in fact, this is exactly what I'm trying to say awkwardly :wink:
ziggy
ziggy
Re: Ferrari F138
I think it's still all about downforce. We've seen it on the new Mclaren and today on the Ferrari. They're all trying to get as much air as possible to the back.
They can add downforce on the front quite easy by changing the front wing, adding downforce on the back of the car is another story. Thats why they use pull-rod suspension, a barely legal high nose and modified side pods. Just to increase the airflow to the back of the car. I think the black end of the car will be totally different at the first GP. The one on the pictures seems to simple.
Redragon
19
Re: Ferrari F138
If I wasn't busy editing and reading your great posts and discussion I would make a couple of pictures of same object, same focal lens but moving the camera slightly down or right. You will see that with a wide angle lens the distortion is big
Lorenzo_Bandini
Lorenzo_Bandini
Re: Ferrari F138
Rhodium wrote:there is no sense between this photo .... and this one .... isn't it?
the sidepost and the exhaust are the same as last year. I even think the chassis is the last year chassis and just the front end and the rear wing is new.
I expect them to change radically at the first test.
F2012 :
F138 :
