Got it, so that way the conclusions from the article are still valid.ringo wrote:The pistons are a compressor. Agree?
So the rule applies in the same way. Intercool between compressor stages.
I didn't say it was bad. It is definitely good if you run a lean mixture. It is definitely good if you reach knock conditions and can avoid them with intercooler.ringo wrote:It's a misconception that having an intercooler is bad, or a waste of time.
But I question how much it adds (if anything) if you have a set amount of fuel to burn and combustion process is not a problem.
I still don't understand what you mean here.ringo wrote:What you do to improve efficiency is scale back that power to the same level as the non intercooler setup and you realize that you will have gains.
It's about pressures, not temps there.ringo wrote:For every compressor stage, try to reduce temperatures. It always helps. Increased Mass flow with the same work is what you want. in fact it is this same density reason as to why engines lose so much power in brasil on for those hill climb cars.
As far as turbines go, it is all in the article. Intercooling=bad, intercooling+ reheating=good.ringo wrote:And wuzak mentioned preheating with the gas turbine. If i remember correct, Honda did this with their ra168 engine. But instead of reheating the air,which would be a negative effect, they preheated the fuel instead. I'm not sure what effect that has but it was positive.
Intercoolers are very costly for gas turbines, and that's because they are water cooled and quite huge. But sometimes the price is very much worth it. Reheat with intercooling gives efficiency gains, no question about it.
Before we know what conditions they are run I don't think there's much to discuss.ringo wrote:But we don't have to argue this really, we've seen modern cars with direct injection using intercoolers. And if they weren't necessary makes like BMW wouldn't invest so much aerodynamics and packaging know how to place these things in their cars. Even going as far as to have water to air cooling.
