Left is FW36 in the configuration raced only in Japan and USA, right is FW37.
maybe its due to the angle of the shot of the fw36, but it looks like the sidepod of the 37 is 2-3cm lower than on the 36tomazy wrote:I did a quick comparison photo, too bad I couldnt find a better resolution image of FW37. Keep in mind, that the angle of thepictures is not perfec and that FW36 is going throu left turn at speed, so the loads on the suspension is diffirent than on FW37 on pit lane speed limiter.
http://s29.postimg.org/harl4jbhj/image.png
It's the angle, look at the height of the roll hoop camera.Johnlub wrote:maybe its due to the angle of the shot of the fw36, but it looks like the sidepod of the 37 is 2-3cm lower than on the 36tomazy wrote:I did a quick comparison photo, too bad I couldnt find a better resolution image of FW37. Keep in mind, that the angle of thepictures is not perfec and that FW36 is going throu left turn at speed, so the loads on the suspension is diffirent than on FW37 on pit lane speed limiter.
http://sport.bt.com/more-sport-hub/more ... 3961386443Bottas believes the car is an improvement on last year, and will only be enhanced over the remaining two tests scheduled for the Circuit de Catalunya in Barcelona.
But as to how Williams will fare, the Finn is unable to say, adding: "There are no massive differences (with the car) to last year, but a lot of positives.
But the car wasn't in the best configuration at Jerez unlike the FW36 was at the top of his evolution in Yas Marina. It's the same for the PU.PlatinumZealot wrote:Massa said the engine felt less powerful in Jerez than at the last race in abu dhabi.
Yes, Pat Symonds keep the same phylosophy than 2014 car. His idea is he can't create an perfect car as Mercedes in all areas because he hasn't sufficient means to it so he prefers to focus on one area to develop it fully without ignoring others areasLookBackTime wrote:Re: Williams FW37 Mercedes
Post by LookBackTime » 15 Feb 2015, 15:48
Williams retains low-drag trait on its FW37 2015 Formula 1 car
http://www.autosport.com/news/report.php/id/117666
