2018 pre-season testing thread
max_speed
max_speed
Re: 2018 pre-season testing thread
Update from McLaren
Don't expect to see Fernando Alonso back out on track for a little while - McLaren are expecting at least a delay of a couple of hours as parts of the car were damaged in the gravel (in addition you'd presume to the wheel)
And confirmation from the team that the wheel problem caused the spin.
[/quote]
seems like mclaren is not getting over with bad luck they had for past few years
F1Krof
95
max_speed wrote:
26 Feb 2018, 11:46
It's not bad luck, merely bad design.
Wroom wroom
GoranF1
GoranF1
151
turbof1 wrote:
26 Feb 2018, 11:46
GoranF1 wrote:
26 Feb 2018, 11:42
mclaren111 wrote:
26 Feb 2018, 11:36
does this means 2 hours or possible more?
Gonna say definitely more. Floor and diffuser will need to be patched and they will have to investigate the broken wheel nut and possible the other wheelnuts as well. Don't expect them to be out again before the afternoon.
god damn.....i heard before the crash Alonso was setting faster sector1&2 times than Bottas
F1Krof wrote:
26 Feb 2018, 11:47
max_speed wrote:
26 Feb 2018, 11:46
Or something as simple as the wheelnut not being fitted correctly.
GoranF1 wrote:
26 Feb 2018, 11:49
Session 1 of day 1 of testing - times aren't important, reliable and consistent data is. You don't go out to set fastest laps from lap one, you go out to check systems and get some data. Fast times come later. The only reason for setting fast times is to attract attention and thus, hopefully, sponsorship.
Jolle
Jolle
133
turbof1 wrote:
26 Feb 2018, 11:49
F1Krof wrote:
26 Feb 2018, 11:47
max_speed wrote:
26 Feb 2018, 11:46
Even if that is the case, there are little hooks that prevent the wheel to come of. Could be a double failure... all in all, not something that should happen and you don't want to happen. Bit like Hamilton's wing coming off a couple of years ago at his first lap at winter testing.
djones
djones
GoranF1 wrote:
26 Feb 2018, 11:49
To be fair, he was on super soft and Bottas on meds.
F1Krof
95
GoranF1 wrote:
26 Feb 2018, 11:49
turbof1 wrote:
26 Feb 2018, 11:46
GoranF1 wrote:
26 Feb 2018, 11:42
Also on supersofts was he. Don't get carried away so far.
Wroom wroom
GoranF1
GoranF1
151
johnny comelately
johnny comelately
110
Just_a_fan wrote:
26 Feb 2018, 11:56
GoranF1 wrote:
26 Feb 2018, 11:49
reliable data can only come from going quick
Bisonas
Unfortunately logic says its not a loose wheel nut or a wheel gun setting error as Alonso would have felt a loose wheel nut or a loose wheel earlier.
Obviously something snapped/failed all of sudden.
If its a wheel nut failure they wont know if its one wheel nut or the whole batch.
They will have to run conservative to find out.
If it is a design error on the wheel nut or the whole wheel securing system, then its even worse.
Even if they just have a suspicion that it is just a wheel nut failure but may happen again, they will probably order a new batch of wheel nuts flying in.
It is kinda disappointing yea.
But i still think and hope Mclaren will be in great shape this year.
The sport needs it.
johnny comelately wrote:
26 Feb 2018, 12:01
Just_a_fan wrote:
26 Feb 2018, 11:56
GoranF1 wrote:
26 Feb 2018, 11:49
Total tosh.
alonso's body language is totally: "here we go again."
Ishwar030
Ishwar030
Santozini
Santozini
Ferrari is out, took them a while
