Ferrari SF21
ryaan2904
ryaan2904
36
Re: Ferrari SF21
f1rules wrote:
10 Mar 2021, 15:40
interesing cape
https://pbs.twimg.com/media/EwH0e5cXYAc ... name=small
Is that tiny inlet beneath the kaspersky logo there to feed the S duct?
CFD Eyes of Sauron
Mandrake
Mandrake
Re: Ferrari SF21
Interesting how with little colour change and form tweaking the nose can look that much different.
Surely there's a development, but without changing the crash structure there is only so much they could actually do I guess
ryaan2904
ryaan2904
36
Re: Ferrari SF21
JPBD1990 wrote:
10 Mar 2021, 15:44
Any insights from rear suspension? We know this was a focus and where 2 tokens were used. There has been much talk of the Mercedes rear suspension, and possibly red bull converging on a similar path too. Can anyone tell from the available pics where this falls? Doesn’t look particularly radical from what I can see, which is obviously limited.
I think the sidepods and barge boards look quite advanced and well done. The rear end of the coke bottle though, appears less tapered than last year - despite their spiel saying the exact opposite. Perhaps just not flattering pictures as yet.
I think you'll notice the taper when top view images are released. The rear section of the merc philosophy cars are lengthier as compared to Ferrari or redbull. Their side pods also start much further as compared to Ferrari. So it might not look like much when viewed from the side. Lets see whats there when the top sections are available
CFD Eyes of Sauron
Re: Ferrari SF21
The rear bodywork is very wide on the new car where it runs back to the rear suspension.
ryaan2904
ryaan2904
36
Re: Ferrari SF21
Anybody else notice how Ferrari have completely removed those cooling louvres on the cockpit just below the halo? Is that good? :?:
CFD Eyes of Sauron
wowgr8
wowgr8
29
Re: Ferrari SF21
Last year they showed the 2019 front wing on the 2020 car at launch then brought a new one (the one they used all through 2020) at testing. I'd take these pics with a pinch of salt
ferkan
ferkan
31
Re: Ferrari SF21
Just_a_fan wrote:
10 Mar 2021, 17:55
Its wider but also angle is different.
Re: Ferrari SF21
Ferrari is one of the most modified cars i can see (Alpine also is quite different from the old Renault).
They managed change the nose and cape around the structure of the old nose.
Sidepods went even more in Red Bulls direction, inlets very similar, drop more noticeable.
Looks more "trendy" closer to what the big boys are doing, let's see how fast it is.
Re: Ferrari SF21
ferkan wrote:
10 Mar 2021, 18:01
Just_a_fan wrote:
10 Mar 2021, 17:55
One can see the gap between the bodywork and the inner face of the rear windows is much reduced in the new car.
senja
senja
Re: Ferrari SF21
Schifty wrote:
10 Mar 2021, 15:16
The body work i like it, but really Ferrari ? seeing the choice to put Mission Winnow in flashy green on matte red and cartoon paint number ??? Just about this, i'm worried about if those changes maded are good. I mean if they can't properly make a decision about the look of the car, they propably dont also about the chassis too.
Anyway i dont think all the chassis will be used at Bahrein, i see too much changes for only 2 token :/
And everything you see is done without single token used. The tokens are spent on rear suspension, that you can't clearly see on these photos.
Re: Ferrari SF21
Morteza wrote:
10 Mar 2021, 17:41
Nicolas Carpentiers wrote:Apart from the different geometry (front element of the top wishbone seems to attach further forward to gearbox), there is something new in this area, see yellow. Not sure what is it. Aero device (it was part of the bodywork in 2020) or mechanical one (but what)?
https://pbs.twimg.com/media/EwIPKBQXAAI ... ame=medium
It's bodywork IMO. Ferrari usually put a vane there, in the air exit, to enhance air extraction.
the-race.com
aerofoilf1
aerofoilf1
247
Re: Ferrari SF21
Changes to the floor edge (many teams have also gone to a double element above the floor edge for 2021) and the forward sidepod vanes
astralx
astralx
Re: Ferrari SF21
FDD
FDD
82
Re: Ferrari SF21
Morteza wrote:
10 Mar 2021, 17:41
It looks to me that they manage to mount lower wishbones higher. Am I right???
wowgr8
wowgr8
29
Re: Ferrari SF21
https://the-race.com/formula-1/ferraris ... gh-tokens/
Because of the two token limits Ferrari has not been able to do it in quite the same way as Mercedes. So instead of mounting the rear leg into the crash structure – which was the Mercedes solution – Ferrari has instead created a longer gearbox casing stretching back into that area and mounted the suspension leg onto that – still much further back than before but without being mounted onto the crash structure.
Spending the tokens on a gearbox change has allowed Ferrari to make a further significant change. The differential has been raised so as to create deeper side channels in that aerodynamically-sensitive area. The new casing incorporates that change too.
Regarding the power unit, gains in excess of 20bhp have been made though that would still appear to leave it some way short of reclaiming the power that was lost to the 2020 tec directives.
