Vanja #66 wrote: ↑28 Jan 2023, 17:08
400-500mm shorter WB with 100-200mm shorter nose (without swept front wing naturally) would help a lot, though only if the width decreases to 1.9m max. 50mm narrower tyres will do the trick. Leaving the bodywork width would increase the risk of race damage, so hotheads would take more care while overtaking.
Why complicate things. Remove wheelbase regulation and limit the absolute lengths of the car to 4.5 meters.
Narrower tires and also smaller ones would save a decent amount of weight. (Just go back to the previous diameter and have actually low profile tires with the 18" rims...)
Not sure about your last point. Why would it increase the risk. At worst it would remain the same IMO. Maybe it would decrease it because driver inputs would lead to much quicker responses with shorter and lighter cars. It's easier to avoid something with a go-kart than a bus. But racing against each other would certainly improve, I think.
