Ferrari F1-75
Marc.W
26
Re: Ferrari F1-75
Emag wrote:
17 Feb 2022, 16:01
So very little undercut which was difficult to see on the leaked image. But also, the top of the sidepods is not flat, as some people were saying, but rather sculpted to a "U" shape like I expected.
Unique concept all around. Seems like they are trying to take a little from all the other concepts we have seen so far and merge it into one.
That fits with the rumours that they didn't really want to pick a direction and just went every direction
JPower
JPower
43
Re: Ferrari F1-75
https://www.motorsport.com/f1/news/reve ... e/8253654/
Looks like Ferrari came up with a way to homologate the nose section so they can change designs without needing to re-crash test.
FittingMechanics
FittingMechanics
16
Re: Ferrari F1-75
JPower wrote:
17 Feb 2022, 16:05
Neat solution. It seems kind of obvious but maybe it is hard from a design/manufacturing standpoint so teams did not use it.
JPBD1990
JPBD1990
49
Re: Ferrari F1-75
The front wing can’t be final as there are slots all the way to and under the end plates which is illegal. I’ve noticed every car launch has featured this, but the cars that have run on track definitely do not.
Does anyone know if ferrari’s shaking this baby down at fiorano?
jumpingfish
Re: Ferrari F1-75
JPBD1990 wrote:
17 Feb 2022, 16:10
I read that shakedown will be in Barcelona 22.02
JPBD1990
JPBD1990
49
Re: Ferrari F1-75
Also we all heard the rumours of ‘vertical’ sidepods which we can see now was clearly accurate and refers to the outer most surface of the sidepods.
Makes me worry about the rumour that Ferrari aren’t happy with the windtunnel results as if the other rumours are accurate why not this one?
Re: Ferrari F1-75
I knew I recognized that shape from somewhere.
dren
227
Re: Ferrari F1-75
PhillipM wrote:
17 Feb 2022, 15:58
Sevach wrote:
17 Feb 2022, 15:48
They are ginourmous intentionally, if they removed the concave factor(which i'm pretty sure isn't necessary for cooling)
I'm pretty sure it is, they're dropping the pressure there by sheilding it with the raised outer sidepod area, to draw cooling air out of the gills better, then using that shoulder to roll it and keep it attached tightly to the centreline of the car to dump it below the rear wing
That's what it looks like. Keeps the tire wake and cooling exit flows separated while having some cleaner air pull in around the undercut towards the rear. It looks like they really focused on clean flow to the rear wing with that roll hoop/intake.
Honda!
JPower
JPower
43
Re: Ferrari F1-75
JPBD1990 wrote:
17 Feb 2022, 16:12
We also had rumors of pullrod front suspension. I would take all rumors with a grain of salt.
Quantum
Re: Ferrari F1-75
Will there be a a significant charge from the radiator louvres emitting heat, with that heat being integrated into the flow creating a Coanda effect?
"Interplay of triads"
Mat-tes
Mat-tes
30
Re: Ferrari F1-75
OO7 wrote:
17 Feb 2022, 16:02
What's going on under the "San" of Santander on the nose in this profile shot? There are a couple of downward sloping (downward from front to back) curved lines or slots.
https://pbs.twimg.com/media/FLzSgbUWQAc ... =4096x4096
That's just the underside of the opposite side of the wing, it looks like the nose but it's not.
LM10
LM10
121
Re: Ferrari F1-75
JPBD1990 wrote:
17 Feb 2022, 16:12
There have not been rumors of the engineers not being happy, but some of the engineers having doubts. And the only person who came up with that rumor was Leo Turrini. No one else.
Herr_Koos
Re: Ferrari F1-75
JPBD1990 wrote:
17 Feb 2022, 16:10
Pretty sure the FIA show car had slots all the way up to and even into the end plates?
dren
227
Re: Ferrari F1-75
Double t-tray VGs similar to the AM. It looks like there is a small squish area between the tub and tunnel inlets similar to on the Mclaren, but can't quite tell in the pictures.
Honda!
OO7
OO7
171
Re: Ferrari F1-75
Mat-tes wrote:
17 Feb 2022, 16:16
OO7 wrote:
17 Feb 2022, 16:02
I think you're right Mat-tes, otherwise that part of the nose would be too thick from top to bottom. =D>
