Mercedes W16
CLKGTR
CLKGTR
101
Re: Mercedes W16
Front pushrod shroud is bent - flow conditioning?
Bence
Bence
Re: Mercedes W16
Emag wrote:
25 Feb 2025, 23:52
...but the similarities brake apart once you look at them in motion and notice how much of the track space these behemoths take.
For me it's strange that nobody seems to remember that the pre-94 cars were around 15cm wider than today's machines... OK, wheelbases and overall length grew, but what's more important in Monaco? :D
Lasssept
47
Re: Mercedes W16
Lasssept
47
Re: Mercedes W16
:-k
@FiftyBucksVT
Vappy
Vappy
Re: Mercedes W16
The load on that wing must be enormous. I'd be keen to see a comparison to other teams. @lasssept, have you seen footage of other cars and been able to gauge the difference?
venkyhere
venkyhere
Re: Mercedes W16
isn't this what happens with every med/high DF wing (on any of these cars) when the car brakes at the end of straight without DRS ?
yooogurt
40
Re: Mercedes W16
venkyhere wrote:
27 Feb 2025, 11:14
That's what Merc was complaining about in 2021 when RB got a ban for their flexible rear wing.
FORZA FERRARI!
Venturiation
Venturiation
101
Re: Mercedes W16
yooogurt wrote:
27 Feb 2025, 11:18
venkyhere wrote:
27 Feb 2025, 11:14
Not at all, redbull was 10x worse
Re: Mercedes W16
This wing is actually tilting back MORE than MCL38 wing design that got banned after Baku and MORE than RB16B flex wing from Spain 2021
CjC
CjC
Re: Mercedes W16
Vanja #66 wrote:
27 Feb 2025, 12:01
https://pbs.twimg.com/media/GkyP-5EWgAE ... ame=medium
So how is that allowed?
Just a fan's point of view
Re: Mercedes W16
CjC wrote:
27 Feb 2025, 12:12
Cars don't have to be legal in tests, safety homologation is all that matters
Farnborough
Farnborough
111
Re: Mercedes W16
While it can definitely be seen moving, this is exaggerated by, relatively, the rear tyres "dropping" out of camera framing geometry when brakes are applied and rear suspension moves into more extension.
You'll need to separate the two components in movement to fully define wing alone.
Just enlarge image as you watch it, the left wheel in frame can be seen, along with top rear suspension leg, moving substantially downward (in reference to static in frame image logo) as he comes hard onto brake effort at maximum retardation.
Take one movement from the other to realistically assess the wing's bending characteristics.
HungarianRacer
HungarianRacer
36
Re: Mercedes W16
Vanja #66 wrote:
27 Feb 2025, 12:01
Those lines are not even remotely honest... The red line is sitting spot-on on top of that Mercedes wing on the left image, while the yellow is clearly cutting through the upper flap on the right... Not to mention, the focal lenght on those cameras are unlikely to be the exact same, a more relevant and good faith comparison would be the dip measured IN PROPORTION to the base heights of the wings, but even then it's a medium-high DF wing vs low-medium DF (in comparison to McLaren)....
Farnborough
Farnborough
111
Re: Mercedes W16
HungarianRacer wrote:
27 Feb 2025, 12:28
Vanja #66 wrote:
27 Feb 2025, 12:01
Those lines are not even remotely honest... The red line is sitting spot-on on top of that Mercedes wing on the left image, while the yellow is clearly cutting through the upper flap on the right... Not to mention, the focal lenght on those cameras are unlikely to be the exact same, a more relevant and good faith comparison would be the dip measured IN PROPORTION to the base heights of the wings, but even then it's a medium-high DF wing vs low-medium DF....
There's no difference, its the distance between image record plane and subject that affects perspective. With same final image size as here and camera location, its comparative in reasonable accuracy.
HungarianRacer
HungarianRacer
36
Re: Mercedes W16
Farnborough wrote:
27 Feb 2025, 12:39
27 Feb 2025, 12:28
Vanja #66 wrote:
27 Feb 2025, 12:01
The wings are tilting backwards, so the focal lenght will absoluely be a factor as to how much upper flap dip you'll observe (increased focal lenght = proportionally less movement further back when pixels are counted). And even if the focal lenght was the same, the images aren't scaled properly (compare the Mercedes wing's width with McLaren's above).
But it's a moot point either way, the yellow line is clearly cutting through the Mercedes wing (zoom in and observe the turquoise stripe on the left, even the right side of the upper flap).
