Well, WB, I noticed that the link you gave is written in german. Could you quote in english the relevant parts?
I think that Mr. Illien theory
could be wrong. I call it a
theory because I don't think he had access to his competitor's proposals before the tender was awarded: he's swiss, that says it all. If he were colombian...
Besides, Mr. Illien has been known to make mistakes (unlike me). For example, I can quote him saying:
"Ilmor... is the frontrunner should Formula 1 become a single engine formula"
"... the ideal engine for an imminent standard formula would be an approximately 3-litre V8 with about a 14,000-rev limit."
So much for Mr. Illien never being mistaken. So, let's speculate, using my infallibility (donskar's style: no mistakes in the last five minutes).
I can understand his/yours point of view, as Cosworth is allegedly providing what Mr. Mosley calls "a
current Formula One engine", which leads us to assume that it’s the already homologated V8 last seen running in the back of a Williams at the end of 2006.
The letter that states this phrase is incredibly transparent, at least compared with NASCAR, a series that doesn't even publish its own regulations.
It's even signed "Yours sincerely, Max Mosley",
but I second flynfrog in his doubts about Mr. Mosley's sincerity (check the video I posted three posts before, which sums up nicely my point of view). I wouldn't say that Mr. Mosley is a despicable compulsive liar that lives a double life that even his wife doesn't know about, but I might (hey, I just said it
However, I can point to Cosworth itself saying about the CA 2006:
"The 2008 FIA Technical and Sporting Regulations included some very significant changes with respect to engines... These regulations
significantly limit the scope and potential performance gains associated with ongoing engine development." That doesn't sound like "current" to me.
CA 2006, 2398cc, 755BHP, 20,000rpm, the envy of BMW: is this what 2010 will bring us? Keep reading: as usual, I have an outrageous theory
Second however: I don't subscribe to xpensive's point of view, either. Cosworth quotes no one less than Gordon Kirby saying: "“The
venerable Cosworth XFE turbo V-8 that will power each and every Champ Car in the 2007 season, sounds even better this year.” Venerable. That's not a synonim for "current", at least in my country, even if, hypothetically, that engine could be running on regular gas.
Is xpensive right on the mark? Cosworth XFE, the engine that gave instant credibility to Champcar (not to mention better lap times at Laguna Seca than Toyota's F1 cars... at 5 million dollars less per car )
Third however: this is when this post really gets thick.
I read a couple of months ago, at our sister site, Racecar Engineering,
a great article, containing the following (in a really small-font image title):
"Cosworth's last V10 engine was the TJ, introduced with Jaguar Racing in 2003. It replaced the LK, the engine that gave Giancarlo Fisichella his win at Brazil that year with Jordan Grand Prix.
"Following significant developments, the TJ (itself a 90-degree V10) included many of the elements that would have allowed Cosworth to simplify its transition to V8.
"However, the FIA had decreed other requirements too, including a minimum crank axis and centre of gravity height. With this in mind, and with progress it had made on combustion and piston design, Cosworth decided to take the opportunity of the rule change to produce a completely new engine.
"The TJ had not taken full advantage of the rules on bore diameter, falling short of the maximum at only 95mm. So, during its development, the company experimented with various bore sizes but, as the aspect ratio of the combustion chamber changed with increasing bore size, the combustion processes suffered.
Since then, much work has been done on single-cylinder test engines to develop mixture preparation, combustion chamber and injector design to make the larger bore size effective."
Last known incarnation of Cosworth engines. CA 2006 on the left, TJ 2005 on the right. Nice room!
Mmmmm. Could Mr. Illien have been taken by surprise by the "much work" done at Cosworth? That's was my first thought when I read Mosley's letter. After all, Mercedes had all the aces up its collective sleeve. Why didn't they win? I'll be there, I promess. Give me one minute more.
Fourth however: race nuts will love this part. Posts here rarely get weirder than this part, let me tell you.
I got
a PDF by Alan Lis some time ago and I read it from top to bottom, twice. Recommended, btw. I quote the relevant parts:
“We learned a lot from that engine,” says principal engineer James Allen. “We had a target from the beginning of running to 20,000 rpm, which we did with that engine, and so we were able to explore the torsional vibration behaviour across the whole speed range. It’s such a big speed range for an F1 engine that you encounter all sorts of problems and go through all sorts of different resonances."
We learned a lot. Aha. It continues:
“The progress Cosworth has made in terms of reducing losses has been significant,” says Simon Corbyn, head of F1 race engineering. “It is the cumulative effect of numerous detail design changes including reduced oil flow, bearing development, finger follower valve actuation and low friction coating technology. All of those things have added up together to give us the results we have now.
The motored friction of a 2006 CA at 19,500 was the same as a 1996 JD at 16,500 if you normalise it for the reduced number of cylinders, and think that has been achieved in 10 years, that is pretty impressive.”
Frankly, I posted the previous paragraph for flyn only: c'mon, mate, it's not that bad. Aren't you interested already? It's truly (from the technical point of view) such a loss that kind of engine? You, better than anyone (except maybe Belatti) know how friction creates heat and thermodynamics go to hell, so...
Finally, I get to the point (phew!): for that, I have to go back to Racecar Engineering article again. I quote:
"Since 1999, Cosworth has used a 'beam head' design on its F1 engines. This concentrates metal in a tall, slim beam projecting up from the head along its entire length. The advantage is it gives the engine the maximum structural strength as a chassis component in the car with the minimum amount of material.
It was an effective way of retaining stiffness, while lowering the overall weight and the centre of gravity of the engine.
When introduced, Cosworth was able to boast having shaved 30kg off the weight of the whole engine, making it probably the lightest in F1 at the time."
CA 200?. The magic is in the beam over the cylinders. Civil engineers will love that. Finite element analysis at its utmost. Check the seals of the pistons: that's what I call elegance
Is all that there is? No.
"However, in 2006, the new rules mandated a minimum centre of gravity height and minimum weight, plus carbon cam covers were banned,
all of which drove head design in a different direction." I give this as an assignment: read in the article all what they had to do, but notice that
they don't say they stopped development.
Final design in 2006. What has happened at Cosworth since?
So,
my conclussion, for the few brave souls that made it to this point:
It's not that simple. Cosworth hasn't remained stationary.
They probably have a new design that takes in account all they learned during 2006, there are too many clues. Take in account that is not Mosley the ones that checks the technical part of the tenders.
They never gave up: they have kept developing an F1 engine, knowing that sooner or later they would have a chance. That's the way of the brave: keep moving and have faith in your own, unique style (hey, that's a motto I could take for myself).
So,
I bet that the new engine we will get in 2010 will not be named CA2006, and if its name is CA2010, it will be a different beast. Besides, they have a full year to design it in its entirety and a brand name to defend. Tremble, Ferrari.
Oh, and take that, Mr. Illien.
Cosworth DFV: ain't Cosworth's works a beauty? People at Cosworth should be dancing (if britons could dance) around it, after winning the tender.
NOTE: All the above is pure, wild, latino-style, totally "Cirish" speculation. No engines were harmed during the writing of this post.
