The less-than-full-width diffuser reminds me of the '91-'92 Jordan.
Intresting, could there be shark gills put in there for this purpose as they are close to the cars centre line???djos wrote:from what i've been reading, this panel that forms part of the "tail" can be removed for extra cooling when needed:
slimjim8201 wrote:Two totally different approaches to the rear suspension...
The suspension arm (at least the structural bit) is CFRP ->xpensive wrote:My guess is that suspension arm has som kind of coating, possibly the same black stuff as the bodywork around.
well the driveline package is bought from Renault, so the assumption would be its the same as what Renault are using. RB are definitely getting the uprated engine, the Renault/Magnetti Marelli KERS, and i would assume the gearbox internals that go with the driveline package.Moanlower wrote:I believe Redbull will use the same gearbox as in 2008..
The 75mm rules apply after the new mirror mount/wing. Ahead of that there is no such constraint.Conceptual wrote:In this photo: There seems to be an odd recess on top of the nose where the pitot tube is.
Can anyone explain how this would be a benefit, and how it doesnt violate the 75mm rule?
Thanks!
