The problem is, how do the FIA keep F1 at'close' competition and allow the needed freedom to use high powered KERS and other recovery systems?WhiteBlue wrote:Which means you have to have AWKERS and multi torque in brake and acceleration mode to make it significant.xpensive wrote:... you basically need to replace conventional brakes as far as possible. Energy will always be mass times speed squared over two, which means that a 700 kg object at 300 km/h holds 2400 kJ to xploit.
I fully support the development of AWKERS systems as used by Williams in the Porsche applications. A basic version of this could be easily applied to F1. However, if full braking was harvested and the technology allowed full reign, it could result in a wide gap opening between competing cars.
I suppose the question has to be; how much of a control formula does F1 have to be while still meeting the need to be at the peak of technology?
It is one reason why I have a paper before the FIA AEC at present on the establishment of official electric racing formula'. One such new formula could be an unlimited development formula without conventional brakes or an ice to compete with for power delivery. Run alongside F1 it could meet the future needs for top motor racing and allow a gradual transition from ice. Perhaps I should ask Bernie?
