flynfrog wrote:The Abrams is by far the best suited tank to its environment. yes it drinks fuel but it is much faster and has a higher payload than any other tank.
Turbines in tanks are crap. The potentially higher speed has no operational advantage and is sacrificed by an engine governor anyway. An engine that needs replacing after 4 weeks of use, drinks three times the fuel of it's direct competitor, busts the owner in maintenance cost, has the heat signature of an independence day firework and leads to 50% of all weapon systems being down for maintenance isn't desirable at all. Have a look at what the Marines are getting:
http://www.globalsecurity.org/military/ ... v-pics.htm
The most technically advanced US combat vehicle will be the new Marine expeditionary fighting vehicle EFV. Specifications of the “EFV”:
• It is an Amphibious Armored Personnel Carrier.
• 3 member crew plus 16 fully equipped Marines.
• Weight:30 tonnes with Marines
• MTU MT 883 Ka-523 diesel engine. 2,780 hp
• Road speed: 72.41 km/h, Swim speed: 46 km/h.
• Range: 523 km on land and 120 km on water.
The MTU 883 series is the most advanced tank engine in the world. An amphibious tank at 46 km/h on water is serious stuff. You need to buy a pretty expensive speed boat to get that and it will not have a 30 mm cannon either.
