S=Sun gear
C=Planet gears
R=Ring gear
The two MGU's (sun and ring gears) vary their speed and direction of rotation relative to the engine's speed (planet gear carrier).
Simulator here (bottom of page): http://eahart.com/prius/psd/
Riff_Raff, knowing that Autogyro can't post here, I thought it only fair to point out that this is essentially Autogyro's transmission idea... something you commented on here: viewtopic.php?p=224723&f=4riff_raff wrote:The electric motor would run at variable speed and variable load. The electric motor's input speed, and even direction of rotation, would determine the output speed of the combining gearset. It would be a form of CVT.
Heck, you wouldn't even need a clutch. If the electric motor input to the differential gearset was the same speed as the turboshaft input, but in the opposite direction, then the differential gearset output speed would be zero.
Is my idea stupid?
Turbine cars of the past like the Howmet TX simply used a single speed reduction gearbox to transfer the power from the free turbine engine to the wheels. For a racing car I think that this is still the best solution. The solution for a practical gas turbine powered passenger car would however be different. Most of them I've seen so far have used the serial hybrid design. That also simplify the turbine engine design since a free power turbine isn't needed, you only need a high speed alternator connected to a single shaft.Formula None wrote:Sort of like a Prius transmission with a turboshaft in place of the ICE? Fixed gear ratio?
S=Sun gear
C=Planet gears
R=Ring gear
The arrangement certainly works... Below is quick mock-up of the required arrangement if you want to use a generator and an electric motor to decrease the speed of the output:-riff_raff wrote:The main idea behind my suggestion was a hybrid system that allows the turboshaft engine to run at constant speed but variable load.
If you wanted to reduce the output speed of the arrangement above by 50% then 50% of the power needs to go through the generator-motor... I agree, that's better than the series arrangement, but obviosuly still a lot more weight than a purely mechanical arrangement.....The parallel system would only need the turbine engine to be sized for 100% power. That would be the best compromise for weight, since the turbine engine gives the best power-to-weight.
For a regular passenger car weight wouldn't be much of an issue since the turbine and alternator doesn't have to be sized for 100% power requirement, you only need to size them for the average power and the average power of a passenger car is rather low. 60 kWe would probably be enough for most typical passenger cars. The engine can be made as a simple single shaft engine with a high speed generator directly coupled to it. A turbine engine is inefficient at part load so a turbine engine sized for the average power need is a much better solution. A PM magnet 60 kWe alternator can probably have a weight as low as 10 kg + power electronics.riff_raff wrote:the serial hybrid would require a turbine engine, electric motor and generator all sized for close to 100% of power requirements. The parallel system would only need the turbine engine to be sized for 100% power. That would be the best compromise for weight, since the turbine engine gives the best power-to-weight.
riff_raff
You have two options:-ringo wrote: One thing though, as the planet carrier goes to zero, or the wheel speed, while the turbine is at rated speed.
Most of the power will be going to the generator ring gear.
Will the generator power the already slowing motor on the drive shaft or charge some batteries.
It looks like a conflicting concept if batteries aren't involved.
correct me if i am interpreting it wrongly.
