Hey guys!
Yeah, I'm back.
After a long learning session with no time for modelling, here's the next update.
mx_tifosi wrote:If you managed to fit a tiny LED strip on the crash structure it would make this even more epic!
That would looking great. I'll think about it.
Shrieker wrote:I'm surprised you haven't actually gotten a job offer. Or have you
I haven't. RBR offers industial placements only for finished students. I'll join them in 3 to 4 years when I'm finished. But I requested Carlin motosports for a placemnt in summer. I didn't got a reply yet.
At first, I finished the rear suspension parts - dampers and wishbones and mounted them. It was not that easy to pack the damper arragement in the tight rear.
Sadly that will be covered by a heat shield. Maybe you could see it through the small vent holes at the rear.
Also the front push rod I fitted to the car.
Now to the exhaust system. Dont ask me why RB covered the whole exhaust system with that carbon fibre shield. Carbon fibre is common for it's less resistance regarding high temperatures. The most epoxide resins used in motorsport resist temperatures up to 130°C (403K), above that, they get soft (special resins up to 180°C). Maybe they covered the housing with a heat protection foil for losing as less as possible caloric heat and therefore energy. So they could improve the efficiency of the exhaust blown diffuser. As I said, only a theory.
That's it for the moment, thanks for watching.
Cheers, Paul
