Here's the best I could find so far, it gets a bit hard since 99% of images have the exhaust down there which obscures the floor. Here's a comparison of floors from last year as well and you can see Ferrari seems to be missing a core compared to some others.shelly wrote:Agree with you owen. it would be nice to compare with some pictures form jerez lat year of the f150 to see. Surely ther could be similar light conditions and pictures at pit exit
That seems complicated and unnecessary?Gridlock wrote:Here's a thought: the regs say you can't do anything with the exhaust gas, but could you (efficiently enough to be useful) transfer the heat from the exhaust container to the floor? Essentially a heat exchange matrix in the exhaust, some very thermally conductive material and then use the diffuser as a radiator?
That wouldn't create a flat floor from underneath though would it?n smikle wrote:The shiny floor was on a few cars last year. Toro Rosso was one car with a thin shiny floor. Maybe they molded the floor on the top side?
Those black areas look temporary- even taped on. I am guessing these are just barriers so that they can isolate the effect of something and that the device between the wing and the wheel is a sensor.Crucial_Xtreme wrote:Lot's of weird stuff went on Friday in session 4. Alonso didn't run for hours as they fixed things and added new parts. Then the car went out for just a couple laps and that was it, Jerez was done.
You can see from the picture below the exhaust has been moved/angled differently from it's previous position. There is also the black cover over most of the bottom of the rear wing that wasn't there at any other point during testing. Also, the big one for me is there is something between the rear wing endplate & the tyre at the floor. But I don't know what and I've only seen two pictures with this configuration.
Here is another picture with the black cover that hasn't been seen anywhere expect on the last few minutes of testing day 4. Also note how little rake the car is running compared to the previous running that day and the 3 days before it. Still not sure what the black cover is. And you can't see from this angle the other side of the car where there is something between the wing & tyre.
