GrizzleBoy wrote:If he wasn't as far ahead as he was during the initial turn in, Lewis would have easily been able shut the door just as he did with Maldonado, but Grosjeans car was far ahead enough and already had enough steering input to actually be nearing closing the door for Hamilton approaching the apex.
Grosjean understeered into that corner pretty badly and almost locked a tire, but he still got past because Lewis gave him the room he needed. Your video shows it, my screencaps show it. What they also show is that Lewis unequivicollay slammed the door on Maldonado,
who was in a similar position to Grosjean throughout the corner phase except for the very end. Lewis drove a line shaped like an "L" that was different to ever other time he went through there. Whether it was due to tires, or him actually defending I don't know. Could be a bit of both. But it most certainly is bullshit that there was no way Maldonado could have passed him cleanly. The only reason he didn't is because Lewis either couldn't control his car due to tire wear, or he ran Maldonado as wide as possible without hitting him to prevent himself from losing the place. Either way, Maldonado had the speed and track position to pass Lewis, his tires were so bad he couldn't do anything other than drive the line he was capable of doing, or he shoved him off on purpose. You continue to look at it from the view that there's no way he could've passed because he didn't, not that he didn't pass because Lewis shoved him off the circuit after Maldonado got too close.
In the end, he's in the wall with zero points, and his attitude of "never say uncle" in the post race interview shows that he still hasn't learned. He should have yielded to collect points. It's not romantic, or cool, and doesn't make for good TV all the time but it wins championships. You can't win every race and you can't keep every position no matter how badly you want to, Lewis either literally doesn't believe this or is too hard headed to see the bigger picture. Living to fight another day isn't cowardice or weak, it's smart.
