Jersey Tom
Jersey Tom
Re: A shameless image thread for the enginephiles
Those machining marks make me cringe. Completely doesn't matter for function, but "roughed" surface machining with big stepover drives me nuts!
CBeck113
CBeck113
51
Jersey Tom wrote:Those machining marks make me cringe. Completely doesn't matter for function, but "roughed" surface machining with big stepover drives me nuts!
I kno wwhat you're talking about Tom - I've handled a quality problem in which hydraulic cylinders were failing catastrophically due to a small machining error - the finish was too rough in a groove (predetermined breaking point).
xpensive
xpensive
214
The air-cooled Honda RA302 wide-angle 1968 V8, not by a fan, but like a motorcycle with fins everywhere;
dren
226
This one had roller bearings for the rods and crank too I think.
Honda!
xpensive
xpensive
214
The Twin Rolls Royce twin-turbo Meteor V12s, from a swedish army tank, mounted in the wooden boat "Sverige S1", enjoy;
https://www.youtube.com/watch?v=QxHETcEWaoo
https://www.youtube.com/watch?v=wvYlMemRR9Y
https://www.youtube.com/watch?v=ECxJ7495yWY
https://www.youtube.com/watch?v=5LzKfP4zia8
Alpina
Alpina
This boat caught fire at one point, it survived but I can't recall the current status.
xpensive
xpensive
214
Aiming for 100 knots apparently; http://www.hundraknop.se/
Alpina
Alpina
566
Looking at those stub exhausts I would say supercharged. Turbo would be a better option though.
J.A.W.
J.A.W.
109
R-R Merlin/Meteor cyl head/exhaust port design reportedly does not cope well with the heat/backpressure
imposed by turbos, at least for for extended running periods.. ..with heat soak softening/distorting things a bit..
Alpina
Alpina
Engines are supercharged.
http://www.jsbab.se/blogg/compressors/
Rockstar786
Rockstar786
First time poster on the forum and absolutely loving this thread =D>
This is a Ford GT40 replica but it looked amazing with rear body work off, it's almost half engine!
Snapped a pic of a Camaro at the same time with an Edelbrock big block motor installed, impressive exhaust headers fitted:)
And an oddity, an inlet valve from a marine diesel engine (Don't know which particular engine but I think from a motor operating on a 2 stroke cycle- may be wrong please correct me if so).
Difficult to represent how large it is in photos, valve length-570mm stem diameter- 27,4mm valve diameter- 133mm.
Note the vanes at the bottom of the valve stem to reduce turbulence during the intake stroke- very interesting engineering.
Happy new years :mrgreen:
Rocco
566
Great pics Rocco. Love the GT40 replica. The intake valve vanes generate swirl - ensuring the fixed injector spray gets access to as much air as possible during injection.
J.A.W.
J.A.W.
109
4T valve then.. & are the valve stem vanes also designed to spin, or are they fixed?
Ford 427 Nascar mill was needed to.. win Le Mans/whip Enzo's machines/fill out the GT 40 engine compartment..
468
J.A.W. wrote:4T valve then.. & are the valve stem vanes also designed to spin, or are they fixed?
7l engines to beat the 3.3l-4.0l Ferraris?
