WilliamsF1 wrote:Andres125sx wrote:When RBR beat Ferrari and Mercedes without the investment of engine R&D F1 was fine and none cared about the manufacturers wasting money on engine department to only be beated by a team that does not need that investment
But now if manufacturers can make the most of their investment F1 is in crisis... Sorry but I don´t see it that way. F1 is a motorsport, so companies investing in engine R&D need some return or they would stop investing.
If that´s what you want then let´s convert F1 into a spec series. Otherwise RBR must assume since they don´t invest in R&D they have a handicap. They were lucky enough in 2010-2013 to not suffer this handicap (thanks to the stupid engine freeze) and they make the most of that situation. None complained, but that couldn´t last long
By your argument why should a manufacturer supply any customer?
Would F1 been interesting with just 6 cars in 2014?
If manufacturers allow for customers then why should they be allowed to reject?
Manufacturers should supply customer teams for the same reason the do so in any other racing series
I´m not sure about the reason some of you think customers should get same engine than works teams. Can you point me to any top serie where that´s happening?
Even MotoGP, with satellite teams run by same teams, have A-spec and B-spec engines. None complained ever. That is racing, top teams fight with top teams, and midfielders fight with midfielders.
The weird thing is some team who don´t build their own material fighting with top teams, that´s the weird part in F1.
And if that TJ13 info is true it would be the most reasonable outcome, if you want to fight with top teams you must build your own material. Finally RBR got it.
