Lotus T127 Cosworth
raymondu999
Re: Lotus T127
That outside winglet/vane seems to be Toyota TF109-like
失败者找理由,成功者找方法
scarbs
scarbs
393
Re: Lotus T127
Looks like they've added a slot along the footplate, I've not seen that on the lotus before
Re: Lotus T127
the whole wing itself is different, the end plate is different, compining both the dual end plate and single end plate together. An also the third plane has an weird wavy shape
zgred
Re: Lotus T127
Slightly better resolution.
raymondu999
Re: Lotus T127
Definitely looks more and more like a TF109 wing
失败者找理由,成功者找方法
mith
Re: Lotus T127
That curved bit on the endplate look very toyotish ;) Her's comparison to TF110:
raymondu999
Re: Lotus T127
So do the cascades and actual plane, no? They look loads like the TF109.
失败者找理由,成功者找方法
mith
Re: Lotus T127
It's not surprising, as we all know, they've hired few aero guys from Toyota. What I'm wondering, is if the gossips about engine and hydraulic deal with Renault will prove to be true.
ESPImperium
ESPImperium
64
Re: Lotus T127
OFICIAL: Cosworth end supply with Lotus.
http://www.f1fanatic.co.uk/2010/09/12/c ... ne-supply/
Lotus are already looking like they will take the step up in 2011 and go straignt into the midfeild action. Also Tony Fernandez also said on the BBC1 F1 Forum that he and his team have just unravled the logistics of what is where in the naming rights of the Team Lotus name. Could the Team Lotus name make its way onto the 2011 entry list???
FW17
169
Re: Lotus T127
Next year Lotus is going to be a copy of RB6 and RB5
raymondu999
Re: Lotus T127
And you know that... how... exactly?
失败者找理由,成功者找方法
FW17
169
Re: Lotus T127
Toyota and MG had a history of copying sucessful aero concepts from other teams in the past. I do not see them risking too much to come up with their own concept from scratch.
But then again they could surprise us with a unique Gascoyne design as the R23.
rich1701
rich1701
Re: Lotus T127
WilliamsF1 wrote:Toyota and MG had a history of copying sucessful aero concepts from other teams in the past. I do not see them risking too much to come up with their own concept from scratch.
Gascoyne is not an Aerodynamicist these days, If anything you would expect the 2011 car to look more like the Force India if Mark Smith joins the team earlier enough to influence the basic aero package.
astracrazy
astracrazy
31
Re: Lotus T127
if the new renault engine and gearbox was put into this years car, roughly, how much extra time would it be worth?
Re: Lotus T127
in your dreams...nothing.if there was an advantage it would be fuel consumption =lower starting weight =better full tank performance...Maybe the Renault box is a lot more efficient than the xtrac thing.So those 2% could be of help in lap time.the main advantage would be getting rid of their major reliabilty issue.
