Red Bull RB7 Renault
raymondu999
Re: Red Bull RB7 Renault
I think they'll probably run back-to-back tests on Friday for KERS. Also, here's Scarbs' analysis of the rear end. http://scarbsf1.wordpress.com/2011/04/0 ... -detailed/
Isn't the wing old, btw? I seem to remember they had a feathered inner edge? As here: (from melbourne:
失败者找理由,成功者找方法
shamikaze
shamikaze
lol, so RB could be acting as if they had KERS, but actually don't then 8)
What also strikes me on the pic's (only jumped to mind know) is the brake-calliper position on the front.
I remember RB started with a similar config last year, but changed that later into the season due to reliability / performance issue's and now they've re-positioned them to this bottom-horizontal position.
Owen.C93
Owen.C93
191
Those ducts may actually stop some of the air that's shooting upwards from the wing interacting with the normal clean air going to the rest of the car.
Perhaps...
raymondu999
Which ducts are you talking about?
失败者找理由,成功者找方法
Owen.C93
Owen.C93
191
raymondu999 wrote:Which ducts are you talking about?
Brake ducts. They are situated under the front wing on the RB.
raymondu999
Most of the ducts are in that place anyways
失败者找理由,成功者找方法
Florio
Florio
http://www.formula1.com/gallery/race/20 ... rsday.html
Picture 11, is that RB KERS? I wonder what changes have gone on so that they are testing it again this weekend.
Owen.C93
Owen.C93
191
Florio wrote:http://www.formula1.com/gallery/race/20 ... rsday.html
Direct link:
http://www.formula1.com/wi/1140x600/pla ... 1mal18.jpg
Scarbs wrote about it:
The Redbull gearbox uncovered:
http://www.sutton-images.com/preview.as ... 1mal18.jpg
Notice that the rockers seem to connect to horizontal dampers on this model (RB7)
hollowBallistix
hollowBallistix
myurr
myurr
So much for all the pro-pushrod guys saying how amazing the packaging on the Red Bull gearbox is. It looks a lot bulkier than the Williams gearbox and diff, and looks quite tall as well...
bonjon1979
bonjon1979
30
n smikle wrote:The Redbull gearbox uncovered:
Kers battery v close to exhausts, bit hot?
Lindz
myurr wrote:So much for all the pro-pushrod guys saying how amazing the packaging on the Red Bull gearbox is. It looks a lot bulkier than the Williams gearbox and diff, and looks quite tall as well...
You mean pullrod?
Anyway... I don't see any detriment to this design. It's a bit tall, but it's very narrow from plan view and it's no taller than the upper wishbones. This works well on the RB7 because most of the airflow comes around the sidepods. Having a taller gearbox is less detrimental than having a wide one where it would actually impede flow. Plus, it can act as a 'shark fin' where it controls the air coming around the sidepods and directs it to the beam wing and diffuser.
I must say, I was a little disappointed reading the Scarbs article. Perhaps it seems underwhelming from a purely mechanical viewpoint, but it's quite clear to me how this was designed with the qualities of the RB7 in mind. Mentioning as much would at least show insight into the philosophy of the Red Bull vs. the Williams, for instance.
Mandrake
Mandrake
hollowBallistix wrote:http://www.autosport.com/news/report.php/id/90496
Horner on about front flex...
I find it very refreshing to see Vettel answering with the giant qualy lever again :D
Is it actually true and legal what Horner says? Due to the rake their FW sits lower? I thought the wing mustn't be closer to the ground than some xxx mm. No matter if you run high rake or very low rear suspension.
imightbewrong
imightbewrong
Better resolution:
Note the small opening below the diff in this picture, probably for cooling.
