This I don't believe... 3 different exhaust solutions for a similar advantage as last year, only if one doesn't lose any of engine's power and the other produces just 373 K temperature...radosav wrote:...
"We do expect a similar advantage from working the exhaust last year, nothing more."
otbsti wrote:gilgen wrote:In the second photo, ignore the hole. Look at the amount of narrowing caused by the pylons!
That was noteworthy, but I'm talking about the interior of the nose cone and the obvious electrical connection running to something inside. Wonder if Ferrari truly went after this idea: http://www.youtube.com/watch?v=mJybR-uW ... e=youtu.be
Yes I am blind.Crucial_Xtreme wrote:So there is two separate openings below the nose. The lower(smaller) opening is more in line with last seasons car & is more in line with regards to it being for cooling functionality. Which makes me wonder if there's more to the larger opening. Interesting to have two different slots under the nose.
He's right. There are two holes. If you look at the picture where you can see the mechanic holding the nose with the wire hanging out of the nose there is a very small oval hole under the opening for the bigger intake.Chuckjr wrote:Yes I am blind.Crucial_Xtreme wrote:So there is two separate openings below the nose. The lower(smaller) opening is more in line with last seasons car & is more in line with regards to it being for cooling functionality. Which makes me wonder if there's more to the larger opening. Interesting to have two different slots under the nose.Please show me the second opening, I cannot find it.
edit: is it the circular hole under the wishbone
I found it now. Its a razor thin strip behind the shark mouth. At least I hope that's it.joeyg02 wrote:He's right. There are two holes. If you look at the picture where you can see the mechanic holding the nose with the wire hanging out of the nose there is a very small oval hole under the opening for the bigger intake.Chuckjr wrote:Yes I am blind.Crucial_Xtreme wrote:So there is two separate openings below the nose. The lower(smaller) opening is more in line with last seasons car & is more in line with regards to it being for cooling functionality. Which makes me wonder if there's more to the larger opening. Interesting to have two different slots under the nose.Please show me the second opening, I cannot find it.
Perhaps they're evaluating tyre/suspension setup changes. This way they can look at the tyre and then compare to their notes to see what setup 301FE115 was on.Clew wrote:Just looking at Forza's picture...Does anyone know what the white chalk 301FE115 markings indicate?![]()
http://img2.auto-motor-und-sport.de/Fer ... 662751.jpg
Yes this is right, I did this picture about 20 pages backCrucial_Xtreme wrote:So there is two separate openings below the nose. [...]
Whats your thoughts on what the shark mouth is for Crucial....seems to me way too big just for driver cooling....Imo I don't think its for Kers cooling as they have a cooling inlet just behind the airbox inlet same as last year....so I think they are up to something tricky.....good to see some innovation from them..... =D>Crucial_Xtreme wrote:So there is two separate openings below the nose. The lower(smaller) opening is more in line with last seasons car & is more in line with regards to it being for cooling functionality. Which makes me wonder if there's more to the larger opening. Interesting to have two different slots under the nose.
Mr.G wrote:Yes this is right, I did this picture about 20 pages back http://papermodelers.sk/hostimages/cgSX ... OyTi5C.jpgCrucial_Xtreme wrote:So there is two separate openings below the nose. [...]
