22.2 Testing of Previous Cars (TPC) shall be defined as any track running time, not part of an Event, in which a competitor entered in the Championship participates (or in which a third party participates on behalf of a competitor), using cars which were designed and built in order to comply with the 2010, 2011 or 2012 Formula One Technical Regulations.
TPC may only be carried out with cars built to the specification of the period and only tyres manufactured specifically for this purpose may be used.
I was consdering something similar..hibbsie wrote:Noticed something interesting about the diffuser height in the relation to the wheel. Redbull may be looking at using the air movement from inside the rear wheels to interact with the diffuser. I have also witnessed that they have also been using flowvis paint on the inside of the rear wheel as well as the diffuser but not at the same time indicating that they are looking at each side of the interaction.
What do you guys think. Am I barking up the wrong tree or are Redbull looking to use the air pumping ability of a spinning wheel to increase diffuser efficiency?
Yes, that was my first thought too. In all videos during regular testing the engine did sound way more irregular. Also I think those are the highest revs (0:18-0:24) I ever heard this season from a Renault engine.Manoah2u wrote:sounds working pretty fine to me.lio007 wrote:pure RB10 sound:
http://www.youtube.com/watch?v=eDvGXmaJgP0
#aerogollumturbof1 wrote: YOU SHALL NOT......STALLLLL!!!
It's Marko but even if it's true (why not - Williams is as fast as Mercedes) it's rather meaningless if separated from everything else. How are they doing on straights, during starts, in slow corners, under breaking, how is tyre management, low/high fuel performance, how long can they maintain this cornering speed, what about fuel consumption etc.Blackout wrote:AMuS said a while ago, maybe some updates RBR brought in the last day didnt work...
But yesterday Marko + AMuS said:Google translationOhne das Motorproblem wäre Red Bull wieder ganz vorne dabei, behauptet Marko. "Ich glaube, wir haben ein gutes Auto. Es gibt Kurvenmessungen, vor allem in den schnellen Kurven, da war das Auto wieder das schnellste. Aber man braucht einen Motor, der funktioniert. Wir müssen jetzt diese Anfangsphase überstehen."Without the engine problem Red Bull would be very front there again, claiming Marko. "I think we have a good car. There are curve measurements, especially in the fast corners because the car was again the fastest. But you need a motor that works. We now need this initial phase survive."
I think at the time Ricciardo was on a new set of tyres and was lapping 3-4 seconds a lap quicker than button once he got clear of him. Fresh tyres, much less fuel on board then I think any car could zip around the outside of another. Doesn't really mean much.Bart111 wrote:Interesting and quite contradictory, isn't it?:
"The Red Bull does not look good," an experienced source, trackside in Bahrain last week, was quoted by Germany's Auto Motor und Sport.
"Nothing seemed right -- the coordination of engine, gears and setup did not fit together. Sebastian (Vettel) was always sliding and spinning his wheels, while the Williams was like on rails," he added.
Button a couple of days before:
“I was driving with Ricciardo for quite a few laps and he couldn’t get past me on the straights. He overtook me around the outside of Turn 11 instead, which is a high-speed left-hander. I’ve never seen anything like that before,”
That is transponder.skwdenyer wrote:Also interesting vents in the "pod" to the left of the stay in that picture, although they might in fact be fins of a heatsink from whatever device seems to have a laser warning label on it mounted to that "pod" of course... are those laser ride-height sensors?
to allow the desired amount of flex whilst avoiding so much it breaks? essentially making it sprung like a leaf suspension? might be why it can be changed easily with the access panel.skwdenyer wrote: There's something interesting going on with the stay, not least because it is clearly incapable of accommodating any significant vertical compressive load. It can only buckle, so what is its purpose?
