Technical Regulations for 2009-2015
Richard
Richard
Re: Technical Regulations for 2009-2015
Is this serious?
Who'd want a gimmick "push to pass" to give the car behind has an unfair advantage? We want cars out on the track racing against each other, not some get out of jail power play nonsense
All it requires is re-balancing the formula to have less dependence on aero and less wake. Hopefully the OWG proposals will be in place in 2011, although I think that'll only be a partial respite.
Giblet
Giblet
richard_leeds wrote:Is this serious?
Richard, please read the wording of my post. It was for IRL, not F1, and I was merely curious how it would work.
F1 has KERS already, and it works by regenerating lost energy under braking, as we already know. IRL doesn't have enough energy lost under braking on ovals to merrit a regular KERS system.
Since you opened up the discussion for this being in F1:
IF this was looked at for F1, a car following another car would have to follow very closely for 5 or more laps, negating the disadvantage it has in the aero department. If a car was unable to follow closely, it could generate no advantage. I see this as not very different from the front adjustable flaps. Something to negate the effects of the lack of downforce from following closely.
If the OWG was able to figure something out that would be great, but so far, not much luck when it comes to one car following another closely to be able to put themselves in a position to pass.
machin
162
Just_a_fan wrote:they don't design the car accordingly is because to do so would compromise its "clean air pace".
Exactly... that's why if F1 is to keep high downforce then the bullet has to be bitten:- make the wings and udnerbody "spec" parts that aren't affected so much by following in the wake. The team's won't do it on their own because they don't want to compromise their clear air/qualifying performance.
Giblet wrote:Something to negate the effects of the lack of downforce from following closely.
Sounds like my "virtual slipstreaming" idea proposed elsewhere in this forum. I'm all for that idea:- either a power boost, or Antony Davidson's idea was to temporarily lower the angle of attack of the rear wing of the following car only on the straights (when the driver demanded it!).
WhiteBlue
92
machin wrote:Antony Davidson's idea was to temporarily lower the angle of attack of the rear wing of the following car only on the straights (when the driver demanded it!).
I think that is as dumb as Bernie's short cuts. In effect you give the leading car a temporary handicap like more weight. It would lead to a complete devaluation of the sport. FiA and FOM must be in a position to shape the series in such a way that we have good sport and overtaking. If necessary they need to publish team votes that go against the interest of F1 to create public pressure. Teams will never make rules for the common good but in the first place rules that help their own competitiveness. It should not be tolerated.
machin
162
I thought the same at first too... "push to pass is a bit too gimmicky, a bit false" I thought... but then I thought about it; cars that can go round corners really fast (they keep the downforce) AND they can fight for places.
I wouldn't advocate giving the following car a MASSIVE boost.. just enough to let him try and OUTBRAKE the other car at the next corner.
The teams still have incentive to build a fast car; if they can stay 1 second ahead of the car behind then the following car won't be in the "Virtual Slipstream Zone", and therefore won't get the boost.
Richard
Richard
machin wrote:Slipstream
Remember the slingshot from a slipstream? ..... halcyon days
autogyro
autogyro
machin wrote:I thought the same at first too... "push to pass is a bit too gimmicky, a bit false" I thought... but then I thought about it; cars that can go round corners really fast (they keep the downforce) AND they can fight for places.
Will not work, because the car in front would also have the same 'boost' button which makes this type of application pointless.
The problem with overtaking is wake turbulance. Get rid of it and start by limiting DF. Boosts like Kers can help but the main reason for Kers is energy recovery and should be used to add to a 'limited' engine power and help a restricted fuel load.
This is where the technical battles should be, not the current pointless battle seeing who can build the biggest air disturbance and match a boeing 747 in drag.
machin
162
My suggestion (on another forum topic I think), was that only a following car could use the push to pass, and only if he were within 1 second of the car infront, i.e in "the virtual slipstream zone"... so it would work... it'd be easy to impliment with the SECU too... They could do it today... simply allow a temporary increase in the RPM limit... we know the engines can withstand it.
autogyro
autogyro
Hmm I see what you mean but I can see enormous problems getting it to work fairly and enforcing it. I think I know what the drivers will think though as soon as they try defending a position from some other car using it.
machin
162
...But that leading car who gets overtaken can use the boost on the next straight to try and get back passed! Brilliant!
autogyro
autogyro
machin wrote:...But that leading car who gets overtaken can use the boost on the next straight to try and get back passed! Brilliant!
I still only see it as a sop to high DF though, sorry.
There is no problem overtaking in lower or zero DF formula.
machin
162
I TOTALLY agree with you.... if I had my way F1 would be for extremely powerful "formula fords" with the latest propulsion technology....
But I know that will never be agreed, and to be fair watching cars go quickly through corners is kind of cool....
autogyro
autogyro
It should be perfectly possible to put a limit on DF and regulate aerodynamics in such a way as to reduce wake turbulance to acceptable levels and keep a high cornering speed.
machin
162
I get the theory... but isn't trying to measure the downforce a bit like trying to measure the coefficient of friction of a tyre.. it is possible, but quite difficult to monitor all the time (too much "noise" in the measurement)... its simply a lot easier to specify maximum sizes of wings etc, but the problem then is that no team would ever optimise for the "following another car" situation (they'd be at too much a disadvantage during qualifying and "free air" running)... so that leads us back to having "Spec" wings and underbody... which actually I quite like the sound of..... instead free up the engine rules and put most of the developement money into propulsion systems....
WhiteBlue
92
machin wrote:I get the theory... but isn't trying to measure the downforce a bit like trying to measure the coefficient of friction of a tyre.. it is possible, but quite difficult to monitor all the time (too much "noise" in the measurement)... its simply a lot easier to specify maximum sizes of wings etc, but the problem then is that no team would ever optimise for the "following another car" situation (they'd be at too much a disadvantage during qualifying and "free air" running)... so that leads us back to having "Spec" wings and underbody... which actually I quite like the sound of..... instead free up the engine rules and put most of the developement money into propulsion systems....
I have explained it often enough that measuring downforce is quite easy. Compared to the two hundred sensors in an F1 car four force sensors at the wheel carriers more are not a big deal. There are only three types of forces in the direction of the cars vertical axis: Downforce, weight and inertial forces from elevation changes and banking. All except DF can be easily measured. The start weight is known and the SECU can calculate the race weight at any time by integrating the fuel utilization. Inertial force are easily computed from the vertical acceleration and the mass which again comes from the known weight. So the SECU will substract them from the vertical wheel forces and you have the downforce. It is so simple, a lot less complicated than an inertial navigation system for aircraft or a precision GPS.
