#aerogollumturbof1 wrote: YOU SHALL NOT......STALLLLL!!!
scarbs wrote:New sidepods vanes on the Merc.
Also the little pod mounted to the right of the cockpit of the sidepod has gone, this surprisingly covered a braided fluid line, so presumably the final build of the car saw this line not fit under the bodywork!
The centre flap on the diffuser gets two triangular endplates
Yes, it's beneficial for the upwash. It uses the air from the small mini diffuser on top of the normal diffuser and beneath the rear crash structure.They try to guide the air away from the crash structure and possible sets up upwash structures left and right from the exhaust area.Blackout wrote:Clever triangular and vertical fins under the crash structure, First time I see em. And I like the RW endplate design, the slits, the stakes and the 'upwash' shape... not new but elegant.
http://img2.auto-motor-und-sport.de/Mer ... 758104.jpg
also more cooling vents on top of the sidepodsThunders wrote:They're still playing around with Cooling Specs. On the last Pictures they have the big Exit again.
and Mercedes previous end plate was quite simple tbh. It seems they just refined the car pretty much everywhere albeit each modification not being very bigBlackout wrote:Clever triangular and vertical fins under the crash structure, First time I see em. And I like the RW endplate design, the slits, the stakes and the 'upwash' shape... not new but elegant.
