dren wrote:Multi-stage compressors are not permitted by the regulations. So stating "there are a series of smaller fans along a shaft." is against the regulations. There will only be one rotor and one stator set of blades -if- it is an axial compressor.
The article is nice, with a lot of good information. A lot of it I agree with: the variable intake trumpets, the ES combined with the controls, and the MGUH placement. The characteristics of an axial compressor are also valid, but for multi-stage compressors.
It depends how you read what a stage of an axial flow comp or turbine actually means. A rotor followed by a stator is the usual explanation.
If you build 3 rotors counter rotating you can eliminate 2 stators thus having on 1 stator. You still only have 1 stage as you have a rotor set followed by a stator. Obviously you'd need 3 shafts rotating inside each other (like a mini gas turbine) and only the HP could turn the MGU H.
