Ferrari SF23
gordonthegun
254
Re: Ferrari SF23
17 Mar 2023, 13:03
OMISSIS
Also changes for round 2 - Saudi Arabia:
https://i.imgur.com/06XYjHg.jpeg
Not even listing the sidepod change :mrgreen:
In my opinion it is the contrary.
The higher image is the one of the launch and the Bahrain race. You can notice from the kind of prodruding of the SIS, very sharp. We all noticed it since car launch.
Instead, for Jeddah it seems Ferrari is a little bit fatter just under the sidepods inlets making the SIS less visible.
Maybe it has been done to get an aero gain, maybe to avoid to burn the 3rd ECU.
Re: Ferrari SF23
I think like vanja and f1nac pointed out the changes are not real but optical illusions from the angle. It doesn't make sense to me to bring this sort of change so early in the season so more likely than not it's an error from nicolas
Listed change on the document at the floor edge
CaribouBread
CaribouBread
101
Re: Ferrari SF23
I remember something similar happened last year where in some pictures it looked like the sidepod had shrunk. Just happened earlier this year it seems :D :oops:
Re: Ferrari SF23
Vinlarr89
Vinlarr89
Re: Ferrari SF23
gordonthegun wrote:
17 Mar 2023, 14:19
17 Mar 2023, 13:03
OMISSIS
https://pbs.twimg.com/media/FraraAIXoAE ... name=large
They must be different side pods. Can’t just be camera angles, one looks smooth and consistent whilst the other appears to have a dramatic change in angle at quite a distinctive line
S D
Re: Ferrari SF23
gordonthegun wrote:
17 Mar 2023, 14:19
17 Mar 2023, 13:03
OMISSIS
These differences could be caused by shadows.
Jeddah photo #1 follow the profile to the right and you will see that the shadow continues to the Jeddah label on the bottom right corner.
Jeddah photo #2 the angle is slightly different but look at both photos and you will see the Jeddah photo has shadows above the shell logo. However ignore the darker portion and follow where the black arrow is located. Just look at the curve ignoring the colour and you will see that it's the same curve. If there was the adjustment then you would expect an angle change but it's not there.
Re: Ferrari SF23
ing.
63
Re: Ferrari SF23
Vinlarr89 wrote:
17 Mar 2023, 14:53
gordonthegun wrote:
17 Mar 2023, 14:19
17 Mar 2023, 13:03
OMISSIS
The angles and corners in the Shell logo aligned with the edge of the shadow are augmenting the illusion of a sharp crease along the sidepod.
In any case, such a sharp crease (as perceived) wouldn’t meet the minimum radius rule. RB have a real “sharp” crease on its lower sidepods and these are quite rounded so as to satisfy the min. radius rule.
Re: Ferrari SF23
ing. wrote:
17 Mar 2023, 16:53
Vinlarr89 wrote:
17 Mar 2023, 14:53
gordonthegun wrote:
17 Mar 2023, 14:19
I agree. There is no crease that I can see. The sidepod hasn't changed at all imo. This is also somewhat supported by the lack of any notation in the mandatory update reports that the teams have to submit.
A lion must kill its prey.
fourmula1
fourmula1
Re: Ferrari SF23
ing. wrote:
17 Mar 2023, 16:53
Vinlarr89 wrote:
17 Mar 2023, 14:53
gordonthegun wrote:
17 Mar 2023, 14:19
Indeed. The shadow meets the corner of the yellow quite perfectly...follow the white outline and it doesn't change how it would if the body work had that crease. I love the way our mind connects dots and fills in the blanks...most of the time it does it correctly and that is how we interact with the world quickly without having to contemplate space and objects.
Re: Ferrari SF23
The guy who first "noticed" the sidepod change is now saying "my bad", there's nothing here fellas.
Re: Ferrari SF23
F1T is the best filter, lots of click-bait BS out there 8)
Twitter "pundits" are getting worse than MSM :mrgreen:
AeroGimli.x
ing.
63
Re: Ferrari SF23
Sevach wrote:
17 Mar 2023, 17:37
https://twitter.com/NicolasF1i/status/1 ... 14336?s=20
He’s usually very good but I wonder if he’s on site taking his own pics or uses supplied pics. If he was on site he would surely have noticed this was just a shadow effect.
Re: Ferrari SF23
Its a drought when the big development to discuss is a few shadows on a side pod...
Re: Ferrari SF23
