2024 Mclaren Formula 1 Team
mwillems
Lucky wrote:
20 Jul 2024, 14:31
4 KPH to Verstappen. About the same difference in the low speed corners, where we are consistently faster. That cornering 4kph is a bigger gain to lap time than the 4kph with DRS open. Significantly bigger. But a lot of folk will look at that DRS number and think there is an issue.
Worth stating, that as usual, along the straights we are as fast as RB and Merc until the last fifth of the straight when the drag starts to impact acceleration. Which is, again, why that number is meaningless. It'd be better to post charts with average minimum speeds through the different corner types and the average speed of the whole of the straight.
This would be a much better reflection of how the balance affects speed and lap time.
-Bandit
Ben1980
Ben1980
Mclaren is not clear favourite.
My money is on Max. Hopefully will be close.
Lucky
Lucky
157
mwillems wrote:
20 Jul 2024, 14:37
Lucky wrote:
20 Jul 2024, 14:31
4 KPH to Verstappen. About the same difference in the low speed corners, where we are consistently faster. That 4kph is a bigger gain to lap time than the 4kph with DRS open. Significantly bigger. But a lot of folk will look at that number and think there is an issue.
The maximum speed is not so important on the lap time, but it makes it very difficult to overtake in the race.
mwillems
Ben1980 wrote:
20 Jul 2024, 14:38
It's tight.
-Bandit
mwillems
Lucky wrote:
20 Jul 2024, 14:39
mwillems wrote:
20 Jul 2024, 14:37
Lucky wrote:
20 Jul 2024, 14:31
It's very difficult to overtake here anyway. So they are setting it up for tyres and for cornering to help them be faster in the race in a way that is more productive and meaningful. The point I make is that the speed is a reflection of the setup balance, not the cars capabilities and that number alone is largely pointless.
But I am now starting to think that part of the reason this team consistently set up the car with higher downforce is precisely because it isn't as kind on the tyres as they would like.
-Bandit
willmesquita
P1/P2 will be Papaya.
To do something well is so worthwhile that to die trying to do it better cannot be foolhardy. It would be a waste of life to do nothing with one's ability, for I feel that life is measured in achievement, not in years alone. ― Bruce McLaren
papayaorange.com.br
LionsHeart
LionsHeart
No matter how qualifying goes, the fact that the car is fast all round is good. I have more questions about the pure speed at Spa and Monza than here.
Ir3NiCuS
Ir3NiCuS
Started to rain
mwillems
This is our average minimum speeds in the corners. The average speed through the corners is more dramatic as we spend much less time at the minimum speed, essentially carrying more speed in and out too. We are looking very nice in the corners. These speeds are a little less impacted by engine modes but could be reflective of a lighter car. Corner 1 is the exception, where RB hit a lower minimum speed, but carry a lot more speed for the rest of the corner for a net gain.
Actual minimal speeds per corner.
-Bandit
Ir3NiCuS wrote:
20 Jul 2024, 15:03
Started to rain
Mercedes masterclass incoming
mwillems
Ir3NiCuS wrote:
20 Jul 2024, 15:03
Started to rain
If we have more DF, this may be to our benefit.
Hopefully we can have a repeat of performance of Silverstone's mixed conditions, where we were easily the best.
-Bandit
Emag
Emag
80
20 Jul 2024, 15:08
Ir3NiCuS wrote:
20 Jul 2024, 15:03
Started to rain
Let's see what new ways McLaren can find out to f*ck things up.
LionsHeart
LionsHeart
mwillems wrote:
20 Jul 2024, 15:06
https://i.ibb.co/5T7GysZ/Minimum-Speeds-in-Corners.png
https://i.ibb.co/R6J2CcJ/Minimum-corner-speeds.png
Thank you. Nice table. The second sector is the most advantageous for us so far. In rainy conditions everything can change.
Let's Go Lando !!!!!!!!!!!!!!!!!!
FittingMechanics
FittingMechanics
16
This is probably soft in Q1.
The track is hot, it will dry off.
