HampusA wrote:wesley123 wrote:MCLREN WINGS DO FLEX TOO.
FERRARI WINGS DO FLEX TOO
LOADS ABOVE 1000N EXCEED THE 20MM FLEX
RED BULL WING GENERATES MORE DOWNFORCE, THUS HAS HIGHER VERTICAL LOAD THUS FLEXES MORE
made it more comprehensive
WHY ARE YOU MENTIONING OTHER CARS?! I´ve said numerous times that other cars are illegal aswell but if you took those two white balls you have on either side of your nose you would realise that this is the RBR section. Thus only discussing RBR.
You are stating that the RBR wing is illegal because it flexes, so i say that the other wings must be illegal too because those are flexing too.
RBR WING IS ILLEGAL, how hard is that for you to understand?
Pretty hard and also false.
A given statement is always false unless it is proven right, you have yet to prove that it indeed exceeds the 2cm flex with a 1000N load on it, so unless you have proven your statement to be true(or false) it is still false.
Funny because you said on the last page that you did not mention other cars yet here you are mentioning other cars...
You know what it is? You are just saying that because you have barely anything else to say then repeating your same statement over and over again, while we are giving new arguments post per post. Now you have nothing to use for a backfire so you start using this. I, and I am not trying to offend you in any way, find that pretty childish of you. We are going on the discussion with you, what a forum is meant for, but you do not come up with any proof or whatsoever and keep shouting the same thing over and over again, you could at least expalin why you think it is illegal and get a more mature stance.
