Good work. I have a lot of comments/changes, but dont take that the wrong way - just want to make sure we have a good rules package to work from
K1 - I would suggest just defining y=0 as being the FWCL, y=3400 as the RWCL, and z=0 as the reference plane. This matches up with the regulation boxes I have built.
K3.5 - Why the 450 and 300 dimension limits? I dont think they are necessary.
K4.3 - The 10mm thickness rule makes sense but I dont understand the other changes here:
-I see you took the 40000mm^2 dimension from the F1 regs, but this is for the whole headrest, not just the portion sitting on top of the cockpit template as we are using. As a result 40000mm^2 would be huge. I had it at 6000, which results in a fairly normal sized headrest.
-"forwardmost point on a transverse line" is confusing if it is just a planar face parallel to and at a distance from plane CC.
-Why the 230 and 725 dimensions? Stating the distance from CC and "must lie entirely above the top face of the template, with the bottom edge lying on the top face of the template" should define it enough.
Have a look at the image in my V2 draft (cockpit template and headrest) to see what I originally intended for the headrest area. Keep in mind that the template below it is enclosed in bodywork.
K4.4 - This rule is redundant since we are requiring that the cockpit template must be enclosed in bodywork
Last sentence of K5.1 - I have no problem keeping the center of area rule but I imagine it is difficult to measure in sketchup.
K5.3 - I would specify that it applies only to the front wing and then get rid of the 450mm dimension (just for simplicity)
-Unless I missed it somewhere, I think you got rid of 3.7.8. I think this needs to be in there because it has an impact on the shape of the nose and FW pillars. Maybe there is a more simple way of communicating the intent of this rule.
K5.5 - I know I included it in my draft but this might be difficult to measure in sketchup.
-I think you removed the language governing the FW pylons, which is probably a good idea since I have made a box for this area, you can just add a simplified rule stating that this box can only contain the FW pylons (maybe with a limitation on their individual width). You may want to change the rule on rear wing pylons to match (there is a box for that as well).
K6.1 - I will make a box so you dont have to include the dimensions at the start. Also maybe the last part should be reworded to just state "the minimum distance between the two elements must be between 10mm and 20mm" (increase the maximum a bit to allow for potential problems with meshing). You also removed the rule stating that the chord of the lower element must be greater than the chord of the upper element, which I would keep.
K6.4 - I have a box for the volume for the exhaust exit, so B, C and D are not necessary. Also I think the exclusion area behind the exhaust is missing, but it may not be too important given that exhaust effects are not simulated.
K7.1 - You removed the language from 3.12.1 (all bodywork situated....and visible from underneath must form surfaces which lie on one of two parallel planes, the reference plane or the step plane, the step plane being 50mm above the reference plane), which I would keep - that way it is unambiguous and in line with the F1 regs.
-You removed 3.12.4 which I would keep, at least in some form (just stating that the boundaries of the reference plane and step planes may be curved up/down with radii of max 25mm, and the boundary of the step plane may be curved up with a max radius of 50mm) - without this you are overly restricted in the shape of leading edge or sides of the floor
K8.1 - I have a template shape included in the reg boxes, you could refer to this instead of listing the dimensions. Also I think you removed 3.16.1b (I also have a template for this) which I think you should keep, otherwise it is possible to have an unrealistically slim engine cover.
K8.2 - The "located between" isnt needed. There is a separate volume for just this rule. Also you removed the language forbidding holes, which I think you should keep in some form - otherwise it is possible to have cooling outlets anywhere on the car.
K8.3 - What is this rule for? I think it is all already covered by 8.2.
K9 - You removed the rule on the orientation of the mirror, without which you could have a mirror pointing sideways with a much lower frontal area. It might be worth considering just ignoring mirrors entirely and not requiring that cars have them. If we are keeping them then I will make a box so that K9.3 can be removed.
One last thing - the original areas I used for inlets and outlets werent really based on anything in particular, I dont know whether the current values need changing.
I will update the reg boxes and PM you a .skp file when I'm done.
