djos
113
Re: A shameless image thread for the enginephiles
J.A.W. wrote:
25 Mar 2017, 07:39
djos wrote:
25 Mar 2017, 07:36
J.A.W. wrote:
25 Mar 2017, 07:35
Australian Chrysler 265 Hemi 'Six Pack', road car mill, - from that same era..
http://www.hooniverse.com/wp-content/up ... x-pack.jpg
I'm always amazed when I see engines that didn't have cross flow heads, just seems so obvious these days.
What's obvious?
The layout was convenient from a packaging viewpoint, & the piston, cam, ports & valves don't care..
http://www.chiheads.com.au/images/2014/ ... head-1.jpg
Considering how wide the engine bay's were back then I'd have thought space was not an issue.
Regarding cross flow, routing air and exhausts through and back out the same side of the engine is just inefficient for several reasons.
For starters, your incoming air is getting heated up by the exhausts costing power and efficiency.
"In downforce we trust"
J.A.W.
J.A.W.
109
djos wrote:
25 Mar 2017, 07:55
That's no biggie, - cold air box & heat deflector... so, any other objections?
djos
113
J.A.W. wrote:
25 Mar 2017, 08:28
djos wrote:
25 Mar 2017, 07:55
https://i.ytimg.com/vi/VfHCbM9_S4s/maxresdefault.jpg
Well now you've thrown away any packaging benefits. =D>
646
this looks interesting
http://www.valiant.org/valiant/hemi-six.html
maybe the 18 deg valve inclination (lengthwise) gives more metal or coolant (than conventional) near/between inlet and exhaust ports
J.A.W.
J.A.W.
109
djos wrote:
25 Mar 2017, 12:38
Hardly, they are a simple bolt on,
& of course, the oil filter, fuel pump & electrics - alternator, distributor, coil, HT leads & spark plugs..
- are all freely accessed on the other side of the engine...
Now djos, what were the supposed "inefficiencies" again?
Singabule
Singabule
J.A.W. wrote:
25 Mar 2017, 07:35
Australian Chrysler 265 Hemi 'Six Pack', R/T option road car mill, - from that same early `70s era..
WOW, alot of risk 'engine fire' then :lol:
It is not a problem with direct injection, but with carb... :lol:
Airflow should be big problem since its share certain space each other. Heat rejector only solve a few of its problem. However, it is classic isnt? Trial and error back day.
J.A.W.
J.A.W.
109
Tommy Cookers wrote:
25 Mar 2017, 12:51
That shallow chamber with valves canted at an 18` included angle - was derided as not being a 'true hemi' TC,
but it is closer to modern practice, & still provides large diameter un-shrouded valves aiming flow towards the cylinder centre, & away from the walls, with the current Mopar 'Hemi' head design being similar, rather than the traditional wide-angle hemi, which needed heavy high-domed pistons to give good compression, & a more complex/expensive valvetrain..
Pix show heads, 245 ci ( 4 Ltr) left & 265 ci ( 4.34 Ltr) right, with the bigger bore's breathing advantage..
J.A.W.
J.A.W.
109
Singabule wrote:
26 Mar 2017, 04:10
J.A.W. wrote:
25 Mar 2017, 07:35
What do you mean "a lot of risk"? Do you have fuel leaks in your car? Or exhaust leaks to provide flame?
It wasn't/isn't a problem in actual use.. or Chrysler wouldn't have built them & sold them to the public...
& why "should" there be " a big problem" - with "airflow"?
Each cylinder runs a pair of independent ports, of correct size...& tuned induction/exhaust like-wise..
Those multiple Webers, & the glowing incandescent - tuned length headers - sure make for an impressive 'image'..
.. you surely must concede....
J.A.W.
J.A.W.
109
A 265 Hemi historic touring car racing mill, good for ~500 hp @ 8,000 rpm.. not too shabby for an N/A pushrod six
See/hear it - in action here at Bathurst; https://www.youtube.com/watch?v=rCRDvkDTIac
dren
226
It's a Toyota...
Honda!
J.A.W.
J.A.W.
109
Tower of power! By Mercury..
MrPotatoHead
A little billet magic that I designed and made recently - seems appropriate here:
djos
113
MrPotatoHead wrote:
22 May 2017, 04:50
https://lh4.googleusercontent.com/_krTE ... 58-h858-rw
https://lh6.googleusercontent.com/7eTU_ ... 58-h858-rw
Those arent image links. (no image extension)
MrPotatoHead
djos wrote:
22 May 2017, 05:12
Does it work for you now?
flynfrog
MrPotatoHead wrote:
22 May 2017, 04:50
https://drive.google.com/uc?export=view ... VJyOFMwUEE
https://drive.google.com/uc?export=view ... FhIclJVR1U
its so. pretty details?
