No, because it specifically relates to multi stage compressors and has counter rotation - which is also illegal.j.yank wrote:Can this be applied to single-stage axial compressor: https://www.google.com/patents/US20130223984
The Heinkel HeS 011 used a mixed flow compressor feeding into its 4 stage axial compressor.dren wrote:I know what you said, but you also said:Sasha wrote:I didn't say multi-stage....I said MULTI-SPOOL
look up two or three spool turbine designs
So I said you cannot have anything with multi-stages because it is prohibited.Sasha wrote:But I think people forget there are ways of getting multi stages within FIA rules.
I thought multi-spool was self explanatory as for why it was not allowed. I guess you could have two or more spools, but only one of the spools with one set of blades on it. That would be multi-spool and fit within the regulations, but it'd be pointless.
As you eluded to in another post, mixed flow sounds a likely candidate. I agree.
I think this part of the technical regulations covers counter rotation.j.yank wrote:I am not sure that there is any statement in FIA regulations about counter rotation. Otherwise, my question was can be the counter rotation applied to a single-stage configuration. In the regulations, there is no specific definition of a "stage". In the case of the axial compressors, should be static blades required to "wrap" a stage?wuzak wrote:No, because it specifically relates to multi stage compressors and has counter rotation - which is also illegal.j.yank wrote:Can this be applied to single-stage axial compressor: https://www.google.com/patents/US20130223984
The rules require the compressor to turn with the same angular velocity as the turbine. In a counter rotating system one shaft is rotating opposite, so it fails the test.j.yank wrote:I am not sure that there is any statement in FIA regulations about counter rotation. Otherwise, my question was can be the counter rotation applied to a single-stage configuration. In the regulations, there is no specific definition of a "stage". In the case of the axial compressors, should be static blades required to "wrap" a stage?wuzak wrote:No, because it specifically relates to multi stage compressors and has counter rotation - which is also illegal.j.yank wrote:Can this be applied to single-stage axial compressor: https://www.google.com/patents/US20130223984
OK, did not know about that.Sasha wrote:how about a design from today not WW2?
PW610
Angular velocity is a vector quantity, so yes.djos wrote:Does angular velocity actually mean the same direction tho?
The rule does also specify that they are on a common axis, as is teh shaft assembly. So the Compressor shaft cannot be offset or at an angle to the turbine shaft, as you hav esaid.djos wrote:I'd have thought that merely rules out the compressor being mounted by say 90 degrees to the exhaust turbine turbine?
Even if you managed to argue that angular velocity doesn't involve direction, you still have the problem with needing two compressor stages, as that's the only reason you'd use counter rotating shafts. It would be heavier (because of the need for gears to reverse rotation) than a simple shaft for a single stage compressor.djos wrote:As long as the counter rotating section is matching the speed of the turbine it could possibly be legal?
wuzak wrote:Angular velocity is a vector quantity, so yes.djos wrote:Does angular velocity actually mean the same direction tho?
If they said angular speed, then it would be no.
It's the speed of the incoming air relative to the blade speed, at the tip of the blades.dren wrote: Probably a 'poor' source, but I was reading the wiki page for individual stages for axial compressors. The 'over 2' is for research compressors, at supersonic speeds. Yes a stretch, but that's what it states. Ron Dennis went on and on about the tech never used before on this PU at the season start, so maybe there is some validity to this?
But I am a bit unsure as to the air speed, is it talking about how fast the vehicle is moving (incoming air speed) or about velocity through the compressor? I'm guessing the former. Which really puts us into the range of PR at 1.2 on the high end.
http://en.wikipedia.org/wiki/Axial_compressor
This comes from a chart on that page:
Industrial Subsonic 1.05–1.2 88%–92%
Aerospace Transonic 1.15–1.6 80%–85%
Research Supersonic 1.8–2.2 75%–85%
Double sided impellers are single stage. This design was used on some early jet engines, like the Goblindren wrote:I kept thinking the dual boost was dual stage, even though the wheel is basically back to back compressor wheels. Or does the dual boost not qualify as dual stage?Blackout wrote:And the compressor is smaller like the honeywell dual-boost TC?![]()
Dren might be right; the compressor might be radial and it's just smaller...
That's not a mixed flow compressor, but a multistage axial with a final radial compressor stage.PlatinumZealot wrote:Still at least two stages.Sasha wrote:That is why I would put my money on a Mixed-Flow compressor
For anybody that is curious it is a mix of axial and radial. normally used in helicopter engines and such.. pretty obvious it is two or more stages of compression. And would not in any way change the exducer diameter of the radial part. So I rule this one out.
http://www.kutriebresearch.com/wp-conte ... -Stack.jpg
It IS a mixed flow compressor no matter how you look at it. Even your own post suggest that it is.Edis wrote:It's the speed of the incoming air relative to the blade speed, at the tip of the blades.dren wrote: Probably a 'poor' source, but I was reading the wiki page for individual stages for axial compressors. The 'over 2' is for research compressors, at supersonic speeds. Yes a stretch, but that's what it states. Ron Dennis went on and on about the tech never used before on this PU at the season start, so maybe there is some validity to this?
http://www.cairdpublications.com/scrap/ ... lin550.jpg
This picture shows the difference between a radial and a mixed flow turbine, the principal is the same with compressors. A mixed flow compressor have a discharge that is not fully radial but neither fully axial.
http://www.full-race.com/store/images/f ... ent-11.jpg
If you look at the unit as a whole, yes it is a mixed flow compressor, comprising three axial stages and one centrifugal stage.PlatinumZealot wrote:It IS a mixed flow compressor no matter how you look at it. Even your own post suggest that it is.
No common turbocharger compressors are correctly termed centrifugal compressors. They are not actually mixed flow. There is only a minor axial component at the inlet, same as there always has been with centrifugal compressors.PlatinumZealot wrote:You are being a bit literal but, Edis you are correct that street car compressor wheels are mixed flow. To the chagrin of some here, I already know that the typical radial compressor is mixed flow(sorry guys). The thing is, the common radial compressor is not called mixed flow these days. For the masses here, I used that photo because I know that is what he meant ( a more pronounced combination of axial then a radial).
I would argue that dual boost is a single compressor, because even if there are two impellers they are fixed to the same shaft and cannot operate independently of one another.PlatinumZealot wrote:I have worked with double sided pump rotors before... Your typical domestic booster pump is double sided. Basically two pump rotors in one if you ask me.. they also deliver high higher pressure ratios. In my post, I said it can be argued to be two compressors. One gas path going in the splits into two different gas paths then joins back again. Heck you can even put two different blade designs on either side if you want. I have no idea what would be the dynamic results of that though. But again in my opinion dual boost can be argued to be two compressors. Why? because say, for example if you stuck two regular compressor wheels on the same shaft facing the same direction instead of back to back, by the wording of the rules it would be no different from a "dual boost" compressor. And yes it would be can be said to be a single stage too... (one step in compression). So it would be up to the FIA to clear this up...
