Mercedes W11
f1jcw
f1jcw
Re: Mercedes W11
matt_b wrote:
01 Mar 2020, 14:15
Avocado wrote:
01 Mar 2020, 13:24
Mercedes unsure if it will run DAS in early races
Riiiiiiiiiiiiiiiiiiiiiiiiiiight ... :lol:
We don't know how much time it is actually worth track by track and it carries a weight penalty, media are overhyping this system like its a silver bullet but if it was then Mercedes would've definitely kept it quiet until Australia.
I wonder if the have a DAS suspension and a sans-DAS suspension they can quickly plugin
If stewards rule illegal do they swap or lock in place
daniellammers
daniellammers
Re: Mercedes W11
Something in my head thinks that DAS is to diverse us from the real revolution they've gone through
You won't catch me driving a race car that I have built.
- Colin Chapman
Airshifter
Re: Mercedes W11
f1jcw wrote:
01 Mar 2020, 15:43
matt_b wrote:
01 Mar 2020, 14:15
Avocado wrote:
01 Mar 2020, 13:24
I would suspect that they have those bases covered already. I think they would assume it's a given that someone will officially protest, and though it appears the FIA might allow it, they would have to be ready just in case.
f1jcw
f1jcw
Re: Mercedes W11
Airshifter wrote:
01 Mar 2020, 16:26
f1jcw wrote:
01 Mar 2020, 15:43
matt_b wrote:
01 Mar 2020, 14:15
FIA is separate from race stewards, that’s the problem
Re: Mercedes W11
f1jcw wrote:
01 Mar 2020, 16:42
Airshifter wrote:
01 Mar 2020, 16:26
f1jcw wrote:
01 Mar 2020, 15:43
Not really, because technical matters can be appealed and it'll end up at a FIA tribunal.
humble sabot
27
Re: Mercedes W11
I suspect the real reason it's a maybe is that it's much like other cornering systems over the years that have required a different approach to the corner than the straight in addition to an additional physical movement. The McLaren extra brake pedal comes to mind. It took a bit of the season to actually profit both drivers because it took getting used to.
The other factor is that optimum tyre cooling on any given track varies with temperature and rain. So on some tracks it just won't offer an advantage. Though those might be the tracks where the slight top speed advantage will come back in to play. Long straights mean cooler brakes and sometimes cooler tyres by the end, but a longer straight means there's also more to be gained by reducing your rolling resistance.
the four immutable forces:
static balance
dynamic balance
static imbalance
dynamic imbalance
zibby43
zibby43
Re: Mercedes W11
F1Krof
95
Re: Mercedes W11
How does it stack against the other cars from this angle? The tightest? No?
Wroom wroom
nico5
25
Re: Mercedes W11
F1Krof wrote:
06 Mar 2020, 12:26
By some margin
Chene_Mostert
-2
Re: Mercedes W11
nico5 wrote:
06 Mar 2020, 20:40
F1Krof wrote:
06 Mar 2020, 12:26
By some margin
not sure, she looks pretty chubby in the center section.
like there is an extra bulge.
a sort of a knocked up goat look to it.
"Science at its best is an open-minded method of inquiry, not a belief system." - Rupert Sheldrake
zibby43
zibby43
Re: Mercedes W11
F1Krof wrote:
06 Mar 2020, 12:26
It's seriously impressive. The extra floor space visible in the overhead shot, starting at the front of the side pods on the W11, compared to the SF1000, is pretty striking (viewtopic.php?f=12&t=28777&start=450).
Ferrari's is not as tight, as they still have a fair amount of their cooling equipment in the side pod region. Instead, Ferrari have a smaller, triangular roll hoop intake and larger shark fin surface area (both of those design choices work together in terms of freeing up flow toward the RW).
Merc is really wanting to force air downward to the rear of the floor and rear diffuser.
mmred
mmred
-3
Re: Mercedes W11
zibby43 wrote:
06 Mar 2020, 22:50
F1Krof wrote:
06 Mar 2020, 12:26
A longer car helps With the tighter rear obviously, but they pay the extraweight and mechanical umbalance
zibby43
zibby43
Re: Mercedes W11
mmred wrote:
07 Mar 2020, 00:24
zibby43 wrote:
06 Mar 2020, 22:50
F1Krof wrote:
06 Mar 2020, 12:26
You can easily offset that weight by innovating with lighter materials elsewhere. There have been some credible "rumors" from someone that works at Merc GP that say the W11 is significantly lighter than the W10, and they have loads of ballast they can play with all over the car.
mmred
mmred
-3
Re: Mercedes W11
zibby43 wrote:
07 Mar 2020, 00:29
mmred wrote:
07 Mar 2020, 00:24
zibby43 wrote:
06 Mar 2020, 22:50
Sure, but compared to a shorter Mercedes car with the same materials technology you still have extra weight and less balance in sharp turns.
Technology Is a given
zibby43
zibby43
Re: Mercedes W11
mmred wrote:
07 Mar 2020, 01:30
zibby43 wrote:
07 Mar 2020, 00:29
mmred wrote:
07 Mar 2020, 00:24
A lot of variables affect balance.
