Absolutely. It's a very interesting development if true. (and I can see from Smallsoldier's post that it is.)dans79 wrote: ↑03 Jun 2021, 17:12If dots are actually applied to the wings in known positions, it will make protesting easier.El Scorchio wrote: ↑03 Jun 2021, 17:02Or maybe a way also of 'encouraging' teams to use the stiffest rear wing they've got.
protesting a rule that won't be introduce until the next race? Sounds like a plan...dans79 wrote: ↑03 Jun 2021, 17:12If dots are actually applied to the wings in known positions, it will make protesting easier.El Scorchio wrote: ↑03 Jun 2021, 17:02Or maybe a way also of 'encouraging' teams to use the stiffest rear wing they've got.
Not protesting the tests, protesting based on article 3.8 in regards to designs or constructions that bridge the gap to the floor... It will be an interesting weekend off track it seems.peaty wrote:protesting for a rule that won't be introduce until the next race? Sounds like a plan...dans79 wrote: ↑03 Jun 2021, 17:12If dots are actually applied to the wings in known positions, it will make protesting easier.El Scorchio wrote: ↑03 Jun 2021, 17:02Or maybe a way also of 'encouraging' teams to use the stiffest rear wing they've got.
With the exception of the parts described in Articles 11.4, 11.5 and 11.6, and the rear view
mirrors described in Article 14.3, any specific part of the car influencing its aerodynamic
performance:
a. Must comply with the rules relating to bodywork.
b. Must be rigidly secured to the entirely sprung part of the car (rigidly secured means
not having any degree of freedom).
With the exception of the driver adjustable bodywork described in Article 3.6.8 (in addition to
minimal parts solely associated with its actuation) and the parts described in Articles 11.4,
11.5 and 11.6, any specific part of the car influencing its aerodynamic performance must
remain immobile in relation to the sprung part of the car.
Any device or construction that is designed to bridge the gap between the sprung part of the
car and the ground is prohibited under all circumstances.
No part having an aerodynamic influence and no part of the bodywork, with the exception of
the parts referred to in Articles 3.7.11, 3.7.12 and 3.7.13, may under any circumstances be
located below the reference plane.
With the exception of the parts necessary for the adjustment described in Article 3.6.8, any
car system, device or procedure which uses driver movement as a means of altering the
aerodynamic characteristics of the car is prohibited.
We've gone around in circles so many times. I think you have posted this reply 4 times by now?dans79 wrote: ↑03 Jun 2021, 17:26
This statement is incorrect. The new tests aren't inplace, but the rule they are supposed to be enforcing has been inplace for years.
as I posted earlier see the bold.
3.8 Aerodynamic influenceWith the exception of the parts described in Articles 11.4, 11.5 and 11.6, and the rear view
performance:
As I said peaty's post is incorrect, a team can't protest the tests, let alone tests that aren't in place yet. A team could only lodge a protest sitting article 3.8nzjrs wrote: ↑03 Jun 2021, 17:52We've gone around in circles so many times. I think you have posted this reply 4 times by now?
The summary of the disagreements are; what you posted applies to front wings for example too, so rather it's the test measures that are more valuable, but they pass the test, but something something intent. Rinse and repeat.
I think this thread is about as circular as the famous PZ FIA conspiracy one.
dans79 wrote: ↑03 Jun 2021, 18:06As I said peaty's post is incorrect, a team can't protest the tests, let alone tests that aren't in place yet. A team could only lodge a protest sitting article 3.8nzjrs wrote: ↑03 Jun 2021, 17:52We've gone around in circles so many times. I think you have posted this reply 4 times by now?
In other words, no team can protest and reference article 3.9, they would have to reference 3.8.
If RBR decides to protests Mercs front wing flaps, they must protest under article 3.8, not 3.9!
I think Mercedes will need article 3.9 to prove this one...
If Mercedes argue that it is done through flexing article 3.9 will come into play.
peaty wrote: ↑03 Jun 2021, 18:27dans79 wrote: ↑03 Jun 2021, 18:06As I said peaty's post is incorrect, a team can't protest the tests, let alone tests that aren't in place yet. A team could only lodge a protest sitting article 3.8nzjrs wrote: ↑03 Jun 2021, 17:52We've gone around in circles so many times. I think you have posted this reply 4 times by now?
This will also required article 3.9 to be proven...
In other words, yes you protest article 3.8 but that article goes hand in hand with article 3.9. We have talk about this many many times already. It's not suprise you didn't understand me (or others), that's why you keep repeating yourself over and over again!
No I understand completely, I think many here don't understand how to interpret the rules. Hence why Abu Dhabi 2014 is such a good reference. In Abu Dhabi, RBR was excluded from qualifying because they were seen to not meet the requirements of what is article 3.8 today. Back then the equivalent of today's 3.9 wasn't even referenced.
Then they should state how they think the rules are/will/should to be interpreted!
