Mercedes W15
Luscion
Luscion
99
Re: Mercedes W15
Detailed shot of Merc's rear wing, taken at the imola GP
Re: Mercedes W15
Out-washing rear wings. You would think it would be bad to out-wash higher than the side plates, but in this generation it seems an out-washing upper wing flap is good?
Re: Mercedes W15
PlatinumZealot wrote: ↑
11 Jun 2024, 10:21
There is a lot of discussion about the rear wing endplate corner, and huge diversity in ideas across the grid.
You can be reducing junction losses, depowering/powering the tip vortex, increasing horizontal expansion via outwash
This video should give a good indication of what changes lead to what outcomes in this region
Clubman1d
Clubman1d
Re: Mercedes W15
This has probably been talked about... If not humor me.
Has anyone noticed how the front wing flexes and brings the area under the nose down?
There is some footage from the nose cam that shows this happening.
I noticed it about 2 races ago.
Matt2725
Matt2725
Re: Mercedes W15
Clubman1d wrote: ↑
13 Jun 2024, 18:03
Quite a few teams have similar characteristics. Christian Horner made a comment about it recently.
Re: Mercedes W15
Clubman1d wrote: ↑
13 Jun 2024, 18:03
Yes. But don't be too distracted by that moving portion, as this was also moving in 2022/2023. The real gains were made from the reshaped main plane, flap and wing edges. Feeds the floor more consistently under pitch and yaw they say.
Clubman1d
Clubman1d
Re: Mercedes W15
14 Jun 2024, 04:40
Clubman1d wrote: ↑
13 Jun 2024, 18:03
Moving wings isn't news, everyone does it, the part that caught my attention was the under-cover of the nose separating and moving down.
clownfish
clownfish
Re: Mercedes W15
Clubman1d wrote: ↑
14 Jun 2024, 09:43
14 Jun 2024, 04:40
Clubman1d wrote: ↑
13 Jun 2024, 18:03
Interesting, do you have any clips showing this? I hadn't noticed it.
Clubman1d
Clubman1d
Re: Mercedes W15
clownfish wrote: ↑
14 Jun 2024, 13:15
Clubman1d wrote: ↑
14 Jun 2024, 09:43
14 Jun 2024, 04:40
I Wish I did.
I believe i saw it in Miami.
If anyone can get hold of a video from the nose camera it can be seen there.
chrisc90
Re: Mercedes W15
Clubman1d wrote: ↑
14 Jun 2024, 18:12
clownfish wrote: ↑
14 Jun 2024, 13:15
Clubman1d wrote: ↑
14 Jun 2024, 09:43
I Wish I did.
Lewis' Rear wing in Miami
George Front wing cam.
Russell rear wing in Canada
Russel front wing in Canada - the new spec.
I dont have the software to draw any lines across to measure the flex, but someone might be able to.
Farnborough
Farnborough
102
Re: Mercedes W15
Against reference on my screen, LH wing is moving /bending backwards with the two spots at upper edge clearly moving downward at maximum load.
GR wing has considerable movement on left side of frame, easily 1cm drop when that video is sized to fill a 13cm height viewing frame.
This is very significant if scaled up, particularly for front wing flap.
Farnborough
Farnborough
102
Re: Mercedes W15
The rear wing, GR Canada, is very clearly moving backwards and downwards at full load.
If you put the Petronas legend at top of viewing frame, then the whole flap gradually appears as it reaches peak loading on final straight, such that you can see over the top edge of flap at that point.
chrisc90
Re: Mercedes W15
Tried to put some lines on. Might be done wrong to how others normally did it on this forum.
chrisc90
Re: Mercedes W15
George's rear with lines
(Apologies for the multi posts)
Big Tea
99
Re: Mercedes W15
Some vid here
