WhiteBlue wrote:Ogami musashi, for once you should remove your rose tinted glasses and admit that downforce always comes with a drag penalty. There is no exception to that rule. In the case of road cars with fierce competition for minimum fuel use in class downforce with even 90% aerodynamic efficiency would not be acceptable. Now tell us honestly that any road car downforce measures would be 90% efficient, particularly considering that the breaking gets predominantly done on the front wheels. You obviously always avoid efficiency and absolute downforce/drag figures because your fancy theories would collaps like a house of cards.
If you know so much about aero as you make believe you should be able to quantify downforce, drag, efficiency, power utilization and the fuel use penalty. If you did that your credibility would dramatically rise compared to now.
Lol, I don't need to be credible. Not more than you are now (that is..not so much).
Drag comes from anything that moves through the air and all is a compromise.
When you house a KERS into your car, you add weight..so now you would need to discard it because of weight? (weight=more fuel consumption).
No of course; you need to save in some other areas;
Same goes with aeros, the drag associated with downforce can be compensated by less drag due to lift.
Your last remark on my credibility is really stupid; Putting numbers require to run CFD/Windtunnel series to be accurate and i don't own neither of the two.
This is especially stupid since you assess your own remark without those same numbers.
So now, stop the personal attacks and do like me: if you can't get along with someone, ignore his posts. I do that everytime i read yours or else i would spend my time repeating the same thing over and over.
Oh and yes, let's talk about number and ponder that:
For an F1 (with DF levels far higher than necessary for a road car) the basic df/drag ratio for a wing is 3,5; The basic ratio for a full venturi channel is 11.
Both combined gave under test done by by RDV on autosport forum (track engineers...is it credible enough to you?) gave a total configuration L/D of 7,7 that is more than 200% the actual L/D ratio for an F1 car and that considering the level of downforce needed to simply allow a car to have better handling caracteristics on mixed surfaces would be about 3 to 4 times less than an F1 car.
The F599XX uses active blowed venturis and no the drag didn't went up higher because:
-It has active systeme I.E the downforce is CUT at high speed.
-The venturis are sealed.
Now bear with that, your continuous pseudo expertise into "what is good, what is bad" is based on dreams not sound science; And i'll post whenever i want to say why i think this is wrong.
