BreezyRacer wrote:I am, and always have been of the thinking that this ride height thing is pure red herring conversation. It is truly laughable how everyone latched onto this idea without anything to go on. It's kind of sad to see it coming to an end really. It's been entertaining to see all these "experts" pontificating on this, that, etc.
Anyone who has ever spent time tuning ride heights and alignment on layout rack knows just how stupid all these assumptions based on a pic of a car parked on un-level ground are. Just a little dip(as little as 10 mm even) where the left rear tire was is enough to give you the pic you see. Put it on a level plane and then we can make some assumptions but just sitting on non level ground? Really ..
And in addition, F1 is, and has been for as long as I can remember, home of the rising rate suspension .. like since the early eighties. What's 300 lbs of fuel compared to 2,000 lbs of downforce, in terms of affecting ride height? It's nothing.
And does anyone here know anything about bump stops???? My God, come on. More time/effort is spent on bump stop tuning than I guess anyone here is aware. Bump stops *are* the rising rate suspension these days, and there is your answer. Now let's let it die and move on.
Maybe we can speculate on something real, such as the F duct and how these other teams will implement it. At least that would be based in something real.
right and wrong
how much will it cost to lower the CG height of the RB6 an estimated 5 millimters?
I´m pretty sure not only Adrian Newey would kill for a lowered CG height of 5mm...
the theme bump stop is of course a hot one ,no question ,for thos e who just think of pur elastomers restricting bump travel and preventing bottoming out of the car..read this:
http://update.smac.fr/files/pdf/smacbum ... 1ec3bbcc3a
funny enough ,the bump rubbers with a lot of damping build in (hysteresis) are temperature sensitive..
so altering their springrate by temps and considerably so..
so all you have to provide to let the car sag for qualy..is provided by a heat gun placed correctly ..
