2023 - McLaren Formula 1 Team
SmallSoldier
SmallSoldier
479
MCLvamos wrote:
06 Oct 2023, 19:44
Was Verstappen on new softs? Both McLarens were on new Softs, but they did set their times a while before the others.
Probably doing banker laps, which means there is still some caution by the drivers to make sure they don’t exceed track limits… Last lap in Q they will probably throw caution to the wind and go for it… Will be interesting to know if they are on the hunt for pole… But so far, pace looks pretty good
Darth-Piekus
-1
MCLvamos wrote:
06 Oct 2023, 19:44
I suppose all were on new softs but track evolved quickly. On another note what is Stroll still doing in F1? Fernando has obliterated him into dust.
FittingMechanics
FittingMechanics
16
MCLvamos wrote:
06 Oct 2023, 19:44
VER was on new softs on his last run.
He was on used softs on his first run (one Lando and Oscar were just a bit faster than).
MCLvamos
MCLvamos
Darth-Piekus wrote:
06 Oct 2023, 19:46
MCLvamos wrote:
06 Oct 2023, 19:44
True, just wanted to find out if Max's advantage was Japan level or maybe a little less of a gap to the McLarens. I guess we'll find out in the next few minutes!
FittingMechanics
FittingMechanics
16
mwillems wrote:
06 Oct 2023, 19:44
FittingMechanics wrote:
06 Oct 2023, 19:42
SmallSoldier wrote:
06 Oct 2023, 19:38
Not sure if I understand the question, lol… a Maximum Lap Time would make sure they don’t go too slow, therefore speeding them up
Ah yes - maximum time - you have to be faster than that time meaning you can't go too slow.
Minimum time lol
https://www.planetf1.com/news/fia-exten ... rule-monza
That article makes no sense. Rule for minimal lap time is silly as there is no danger if cars are quick on outlaps. It is dangerous if many drivers do slow cooldown laps.
This is what F1 reported:
"INCIDENT INVOLVING CARS 44 (HAM), 22 (TSU), 40 (LAW), 81 (PIA) NOTED - FAILING TO FOLLOW RACE DIRECTORS INSTRUCTIONS – MAXIMUM LAP TIME"
Darth-Piekus
-1
Still despite the result the team finally has a car to go for second best.
mwillems
44
06 Oct 2023, 19:48
mwillems wrote:
06 Oct 2023, 19:44
06 Oct 2023, 19:42
Minimum time lol
There is both a minimum and maximum lap time, I was going from your original description which was of a minimum lap time, not a maximum one.
But both serve the same purpose which is to ensure that those on an outlap do not interfere with racing laps by going too slow or too fast so if they have broken the max rule then it is the same principal but the other end of the scale. it is so they don't go so fast that they can't cause issues.
The article explains minimum time just fine.
-Bandit
CjC
CjC
Norris and his track limits!!
Just a fan's point of view
SmallSoldier
SmallSoldier
479
mwillems wrote:
06 Oct 2023, 19:51
06 Oct 2023, 19:48
mwillems wrote:
06 Oct 2023, 19:44
Minimum time lol
There can’t be a “Minimum Lap Time”… Lol
mwillems
44
SmallSoldier wrote:
06 Oct 2023, 19:55
mwillems wrote:
06 Oct 2023, 19:51
06 Oct 2023, 19:48
None the less, there is one!
-Bandit
FittingMechanics
FittingMechanics
16
mwillems wrote:
06 Oct 2023, 19:51
06 Oct 2023, 19:48
mwillems wrote:
06 Oct 2023, 19:44
Minimum time lol
I think there is no "minimum" laptime and that it is matter of how you frame it (what is your frame of reference). If it is time - this is maximum time that can be done, but if it is car speed - this is minimum/worst car speed/laptime you can do.
When you check articles with "minimum laptime" - they always talk about going too slow.
mwillems
44
06 Oct 2023, 19:57
mwillems wrote:
06 Oct 2023, 19:51
06 Oct 2023, 19:48
Yes, exactly, there is a minimum and maximum laptime to ensure traffic doesn't interfere with Qualy laps as extremes at either end would cause a problem.
Reading the rules, the minimum time applies to in lap only, the article was talking about it being extended to in and outlaps at Monza, but here there is a minimum time on inlaps.
Your description of the infringement was of someone going too slow, not too fast, hence it seemed they'd broke the minimum lap time rule.
-Bandit
FittingMechanics
FittingMechanics
16
Very weak qualifying by Norris. Mistake in each part.
Quick but couldn't keep it on track.
If he gets a grid penalty as well - it might be a long day tomorrow.
Darth-Piekus
-1
I don't think Lando is gonna keep P2. He went off track limits I'm afraid and he will probably get his time deleted by that BS rule. There should be leniency regarding understeering.
CjC
CjC
06 Oct 2023, 20:02
Only followed it on the app but P2 was the maximum today? I saw nothing that made me think he had a 23.6 in him?
