Yes, it is not yet time to discusse the new rules or the improvements to the present rulebook.LVDH wrote:I have some plans. I am not sure if I floated the idea on this forum around of even a second championship. Right now I do not see that happening, but there will be a new MVRC next year, that is for sure. And there will be modifications to the rule book. But right now I am so busy with all kinds of things that I will wait to announce the first ideas on a new thread for a while. But if you guys have ideas take a note so you can share them as soon as the time comes.
Sounds good, keep in mind you need two.CAEdevice wrote: I have a good idea about the position of the heat exchangers, but I would need to know wich is the minimum diameter of the pipes that connect the heat exchanger to the engine. 50mm could be enough?
A rectangular shape 50x100 (including 2x phi50) should be ok for both in and out.LVDH wrote:Sounds good, keep in mind you need two.CAEdevice wrote: I have a good idea about the position of the heat exchangers, but I would need to know wich is the minimum diameter of the pipes that connect the heat exchanger to the engine. 50mm could be enough?
Nice, and that leads to victory?CAEdevice wrote:PS: my car converges in 1000 iterations now
On the contrary, it leads to df/dr = 4... My fault: I spent many weeks working on a car that had df/dr = 5.3 @1500 iterations, without looking at the convergence plots (only residuals). When computed with 2500 iterations the performances were much worse.LVDH wrote:Nice, and that leads to victory?CAEdevice wrote:PS: my car converges in 1000 iterations now
