maunde wrote: ↑26 Nov 2019, 05:25
etsmc wrote: ↑26 Nov 2019, 04:53
maunde wrote: ↑26 Nov 2019, 01:36
What do you mean by scrutineering?
The MVRC team check each and every car before each race against the rules to see if they comply or not, if they do not comply then there is normally the first warning and any repeat offences are hit with a penalty, I can't remember how the penalty is worked out but its a calculated amount of time added to your result.
That makes sense - just like normal scrutineering.
Is there any reason you cant automate this?
The scrutineering process has been optimised year after year, now the rulebook is mostly based on volumes that allow a quick check. Also thickness can be visually checked with many stl utilities (I use MeshLab).
A completely automated process would require a closer interaction with the geometry processor (CAD, Paraview, OpenFOAM modules, ... ): it would be easy with native cad format and cad APIs (or maybe with step format), or with very good quality stl files, but this is not granted.
