fizzer wrote:Are they?autogyro wrote:So the jury is still out then and the FIA is still failing to clarify what
'ride height control' actualy is.
We all know that active suspension is against the regulations but how can ride height control be? Every car has it in one form or another.
"Any system, device or procedure, the purpose and/or the effect of which is to change the set up of the suspension whilst the car is under parc ferme conditions will be deemed to contravene Article 34.5 of the F1 Sporting Regulations," it read, adding that; "any self levelling damper system is likely to contravene (article) 3.15 of the technical regulations."
Seems pretty clear to me. Now, what is "suspension set up"? Its broad enough that they could pretty much nail you no matter what changes under parc ferme.
Most the teams DO have ride height control, but they can only use it during the races in pit stops.
source: http://www.pitpass.com/fes_php/pitpass_ ... t_id=40453
putting in fuel is allowed under the rules.So a ride height levelling system is not changing the setup ,as it keeps the rh as it was with empty tank ..to me the whole ruling is written in a wrong way.
