BreezyRacer wrote:Actually we don't care about drag in the diffuser box .. a vortex is the ultimate low pressure creator. Getting a powerful vortex is hard to do with the these very limited diffuser rules so the fact that McLaren have done it is impressive. Note the curved vaning to help support the vortex. Very nice result IMO.
BTW, it's pretty damn hard to create a vortex at the leading edge entry and have it hold up all the way to the tail. I imagine we're seeing two vortexes .. 1 at the entry point, behind the barge board, and another downstream usually around the diffuser box entry.
I have to say that I don't understand all the strakes in the diffuser boxes this year. Seems most teams are trying to spread the diffuser flow out to the sides to take advantage of the low pressure region behind the rear tires but in doing so you reduce the possibility of a highly defined vortex in the diffuser because there just isn't the energy for it.
I think this is a reflection of the fundamental difference between McLaren and Red Bull's philosophies on their respective cars. Red Bull are working the outer edges the most which takes advantage of the rear wheels wake and their tight waist, and served them really well the last couple of years. What McLaren appear to be doing with their entire aero package is working the middle of the diffuser hardest. What is impressive to me is that they still appear to be turning the air outwards to the rear wheel wake, possibly aiming to get the best of both worlds.
I'm just an arm chair analyst but my theory is that the U shaped side pods are designed to supply great quality air to the beam wing, but also to mix with the air going around the side pod to supply air to the top of the diffuser. By raising the crash structure they can pass air over the entire top edge of the diffuser, but in doing so they compromise the beam wing. This means they're focusing on the halves of the beam wing to either side of the crash structure which just so happens to line up with that nice vortex coming off the centre of the diffuser, with the outer edge of the diffuser pulling all that round towards the rear wheels wake. A powerful side effect of this also appears to be that they can run a very steep rear wing that appears to have a bigger than average upper element (certainly when compared to the Renault).
If it works then that could be a very powerful combination that other teams may struggle to match due to the lower placement of the crash structure and focus on the outer edges of the diffuser, even if they do copy the U shaped side pods.
