Ral wrote:What is the difference between mechanical grip and traction? I mean, I can understand the difference as such, but Boullier was saying they needed to work on traction a bit more to get the car in contention for Monaco, clearly not happy with what it is like at the moment. And that kind of bore out in Spain in that their last sector wasn't anything special compared to the other cars.
But wouldn't you need good mechanical grip to get good traction?
i thinks is opposite. Traction refers to the maximum frictional force that can be produced between surfaces (car and track in this case) without slipping, and mechanical grip is 'just' grip made between the friction of tire rubber and abrassive road surfaces. that means, better traction of the car, better mehanical grip. but with traction you not only improve mehanical grip (who felling in slow corners), you improve even aerodynamic grip (in high speed corners)
EDIT: When you are surrounded by current tehnical regulations, you are limited with aero of the car, what means downforce. also think with these Pirelli's tyers, searching for grip and theres performances, improving traction is great idea and direction. last few years whole idea about great traction was forgetted, since 2008. from ban traction control.
