mclaren111 wrote:McLaren's Tim Goss:
Goss also believes the larger bargeboards will be a key visual indicator in the change of regulations and is confident all cars will look more aggressive and attractive, as set out by the requirements of the 2017 regulations revamp.
“The rear wing is also wider and lower - which helps make the whole car look lower and wider,” he said. “And there are some visual styling cues that have been introduced: the rear is swept back in side-view, and the sidepod intakes are angled in plan-view. It's definitely a 'meaner' look.
“And there's a detail in the rear-wing endplate regulations; they step in - and that curviness is another styling feature that adds to the general 'aura' around the new shape.”
Not a lot of the renders of 2017 cars we've seen so far show the "curviness".
How will teams interpret this curviness ?? How strict are the rules in this regard ??
Any ideas Aero Guys ??
Surprised you didn't quote this part
"A lot of the flow structures and physics on the car are fundamentally the same, how the flow is established at the front of the car and then travels back down the car, starts off in a fairly similar way to last year.
“Now what you’ll find is that, in the detail, things start to behave differently, which prompts you to change direction. The 2017 cars will look pretty similar to the layman, but the aero guys have been battling to correct flow-structures at different ride heights for months and months now. We’ve had to rethink lots of different areas on the car, because they’re behaving differently to how they did before.”
Also we'll see some P1 inspired barge boards, nice wavy multi element designs.
